You are getting smoke out of the cat probe hole? Wow it might be bad draft then you need to get a pro out there with a manometer
I don't know where the smoke is coming from. My sense is it's coming from the seam between the collar that attaches the top of the stove to the stove pipe but I could be wrong. We were getting it when that collar wasn't there. It might have been coming from the connection of the pipe to the stove itself. The smell seemed to go away. The dealer guessed enough soot had built up to seal it shut. He added the collar hoping that would correct the problem, so it didn't occur after each time the stove pipe was disconnected for cleaning. Instead, we seem to have caused the problem to recur. But it could be that it's actually been from the probe hole all along. So much of this investigation has required guess work -- hopefully educated.You are getting smoke out of the cat probe hole? Wow it might be bad draft then you need to get a pro out there with a manometer
That would surprise me but i guess it is possibleBut it could be that it's actually been from the probe hole all along.
stove pipe is never really sealed your problem i would say is either with inadequate draft of not enough air. If you dont have good draft you will get smoke no matter what you doI wonder if the leakage from the stove pipe is there but within normal tolerances and the smoke is being forced through because of inadequate draft or a problem with the cold air coming into the burn chamber.
By the time I get home tonight it will be dark but will do that in the morning and post it here.Well you can always raise the pipe but if it is proper height a vacustack cap might help But again i am not there to see it. Can you take a pic of the chimney from outside?
With a properly engaged cat, there should be no smoke smell coming out of the chimney.Are you sure the smoke smell is coming from the stove, rather than from outside? With my house and the right wind we will get a vortex behind the house that will pull smoke from the chimney into the front yard. This smell can easily come in through the front door. Raising my stack helped, but this still happens. The smell is stronger at the front door than it is near the stove.
I haven't had backpuffing in my stove, but it seems like it could open cracks in the stove or pipe, which would then become leaks.
Your draft should be stronger when the flue gets hot after a few hours of use. Does this happen with your stove?
Post a picture of the chimney from the outside if you can. The way I'm reading it even with the extra height the chimney is still just even with the highest peak only 4 feet away? The chimney needs to be 2' higher than the roof within 10'.
The peak of the roof is way more than 4 feet away. The edge of the roof of the second story is about 4 feet back from the edge of the roof of the first story. Even without the extra four feet of pipe, the installation met code requirements.
I didn't read all of the discussion above. Did you ever have double wall connector pipe installed?
How is the OAK routed? Your stove is starving for air as well as suffering from poor draft. With a tall flue and an OAK it shouldn't be, as you know. Something is causing this to happen. Chimneys suck smoke and air out of the stove, it's as simple as that. If it is leaking smoke, something is causing it. Something is preventing the stove from working properly.
How is the OAK routed? What size is it? Is it insulated?Are you referring to the collar connecting the stove to the stove pipe? I think it's double walled. It seemed like it was made from cheap metal but I saw a divider in there. I figured that's double wall.
Webby, if it were your job to fix, how would you go about diagnosing the problem.
It comes from the wall behind the stove up into the burn chamber. I'm not sure of the size. Will take photos tomorrow morning and post them here. I don't believe it's insulated but I'm not sure. It doesn't get all that cold around here.How is the OAK routed? What size is it? Is it insulated?
To test the oak theory I would run it with the oak disconnected for a day, with a nearby window open 1/4".
