Looks like there is a plate in the pic with the ladder?
The stove looks great in that fireplace, by the way.
Thanks! It worked out better than I had hoped
Not sure if i did it right here, but I used chimney cement to fix the metal cap plate to the top of the chimney.
Since it fit so well, I decided not to use stove screws to fix the connector to the chimney. My thought is since it fits tightly, and there is up-pressure from the stove, and down-pressure from the chimney, the screws weren't necessary, and poking holes in the liner (however well-filled by a screw) is just opening up points of weakness, and potential spots for hot-gas to leak out. Not sure if that's the right way of thinking, so I'll go with your advice on this.
Joful makes a good point about that, plus I believe it's code (3 screws into the stove flue collar) for a reason, safety. I was told if it's too tight to get all three in, then at least one.
Good luck with it, nice looking fireplace, stove looks good in it.
I don't think furnace cement is going to adhere well nor seal out rain. The plate should be sealed with a generous bead of silicone. I would remove the plate, completely clean off any furnace cement and get the surfaces dust free. Then put down a fat bead of a good silicone adhesive sealant like GE Silicone II and press the top plate down on to it.
I believe the normal method is to use high temp silicone (black) to seal the plate to the top of the chimney (usually around the edge of the top clay tile). That should keep it air and water sealed. I'd keep an eye on the chimney cement which is more likely to crack and leak, I'd think. The top plate should also be mechanically attached to the chimney either with fasteners (drilled into chimney cap) or tension screws like with a "terracotta top plate". (though some have suggested, you can get by with just the silicone)
After cleaning up, wipe the metal down with alcohol to remove any residual oils before siliconing. You want a good fat seal there.Yeah, I went up and checked today, and it appears that furnace cement isn't the way to go. The weather is going to be crappy for the next couple of days, but as soon as it clears up, I will climb back up there, clean off the cement and go with silicone. The way it is now will work in the short term, but defiantly not the right way to go.
The top plate does have an integral hose clamp that attaches the liner to the top plate, so the liner is mechanically attached at the top.
