Okay... you're resolved to do this. Our fireplace situations are very similar, so I can offer some advice here. I have a flagstone chimney topper, like yours, and I was able to keep it. However, since the liner sticks up a bit taller than the chimney stack (gotta fit the crown collar onto the liner at the top), and my installer wanted to see a certain minimum gap between the top of the liner and the bottom of the flagstone, we ended up raising the flagstone by one extra course of brick
That looks like a short chimney. Leave to the cap off until you are certain the chimney will provide adequate draft for the stove.
Thanks for the info on the windows @akbear @eclecticcottage . I'll start digging into this info and maybe add it to the project list once the stove is set.
You may remember some of my rebuild stories posted at wavyglass... and that the previous owner's improperly-caulked aluminum triple-track storms are actually the cause of some of the damage I'm now repairing. It's hard to describe the frustration I feel when I look at these 240 year old window sills, kept in perfect shape for more than 200 years, and then destroyed in less than 30 years by the inexperience of some stupid storm window installer.I started the process of fixing our remaining original windows here last year-luckily ours are protected by aluminum storms so I can take my time!
I take things a step further. Silicone caulk did not exist when this house was built in 1773, and the house has held up pretty well, despite a lack thereof. It has no place here.It's real easy to be over excited with the caulk gun. When you take into account that water runs downhill it's not to hard to figure out what parts to caulk and which ones not to.
Exactly. In my case, proper soldered copper flashing will never be replaced by adhesive rubber flashing and silicone caulk.There is a lot of stuff that hasn't been totally replaced by alternative materials. In some cases the original still exceeds the replacement.
That is a BEAUTIFUL stone house exterior.... !!
I've been told there have been fires caused by blowing insulation into houses with (possibly unknown) knob and tube wiring. Now, one might think it's impossible to have live knob and tube in a wall, and not know about it... but I just found some cloth wiring on a very old toggle light switch in my house. I'll be pulling it apart tomorrow, hoping it's less antique than it initially appears.Stone houses built in the 20's (at least around here) usually have framing and plaster on the interior side of the exterior walls. Not necessarily originally insulated, but at least there's an air space between the cold stone and the interior or the place to add insulation, usually blown in through holes bored with a hole saw in the plaster for each stud bay often hidden under the base molding.
So here's the short story:
My girlfriend and I were both laid-off recently, within a few months of each other. To save money, I rented my house out, and moved into her's (for love if she asks, but really because mine was more marketable). We now live in her 1920's stone ranch house. 1 story - aprox 1500 sqft, with a semi-finished basement. Heating bills (Natural Gas radiator) in winter are in the $300+/mo range (old house/crap insulation), so obviously looking to find an alternative
My house (the one that I rented out) had an old wood stove in the basement that I had cleaned the holy bat-snot out of, but had, literally, never used.
So, I went and pulled the wood stove out, and now it's sitting on my porch. After lurking on this site, I now know it's a Kent Tile Wood Stove, circa 1985.
Currently, our fireplace has a vented NG log-set in it. I'd like to take the log-set out and replace it with the Kent wood-stove. I've got plenty of clearance on all sides, and the original chimney is the only decent place to run a wood-stove in this house.
I'm thinking that I need to have a plumber come and pull that out and secure the NG lines, then I'll put the Kent in the fireplace. Install double-lined chimney pipe to the top of the existing chimney (cap etc), and probably a blower (suggestions appreciated).
What am I missing, and what should I be looking for? Sadly, budget is a huge issue for us, so I'm stuck with the Kent Tile (even though I know an insert would be better). I'm ok with making an investment to make it safe and warm, but I can't afford to waste money.
View attachment 116289 View attachment 116290 View attachment 116291 View attachment 116288
Good point.I've been told there have been fires caused by blowing insulation into houses with (possibly unknown) knob and tube wiring. Now, one might think it's impossible to have live knob and tube in a wall, and not know about it... but I just found some cloth wiring on a very old toggle light switch in my house. I'll be pulling it apart tomorrow, hoping it's less antique than it initially appears.
