Does the stove have an adjustable trim rate? Certainly looks like you have too much fuel being feed in. Trim it down a few levels and it should help with the clinker/full pot issue!
I found that there is a jumper setting on the control board to adjust the "off time" for the auger. It was set to 2.0 seconds off time on hi setting. There is 1.5, 2.0, and 2.5 off time settings. I changed it to 2.5 off time today before the start up. Hope this is the problem...
You changed more than just the off time in high with that jumper you changed the maximum output you can get from the stove and all of the other firing parameters. You now have your stove in the 50,000 Btu mode.
