Hi All,
Is there a way to get a 23 degree (from vertical) bend in packed stainless 6" pipe? We are installing our new Avalon Arbor wood stove in our 3 story (separate floors) A-frame cabin. We would like to run the pipe inside the house along the same pitch as the roof (22.5 degrees). The pipe will need to pass through 2 floors then out near the peak of the roof. Our stove dealer had recommended Simpson Duravent pipe, but it only has 15 and 30 degree elbows and 15 and 30 degree firestop shield boxes available.
Do any other pipe manufacturers offer stainless, class A, pipe with a 22 degree elbow and a 22 degree firestop (floor pass-through) box?
Have you ever seen/done a similar installation? The dealer suggested running the pipe outside, but that would require a 20'-ish pipe standing straight up in the air (to get the top 10' from the roof) and my husband is concerned about the stability and appearance of the pipe. He is determined to run the pipe inside!
Got any words of wisdom to toss my way?
Thanks for your help,
Stephany
Stephany
