I joined the ranks of Wiseway owners about a month and a half ago. Overall I'd say I'm happy, maybe a 5 or 6 out of 10. We have an circa 1830 approx. 3000 sqft.brick farmhouse in Northern Vermont we are constantly improving. During our first winter the oil bill exceeded $1,000/ month December through February for hydronic baseboard. Something had to be done
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
We have run a pellet stove in the basement and one on the first floor, fairly centrally located, for about 4 years. . We spend a lot of time in the same room with the first floor pellet stove and the noise problem was significant. When the downstairs stove ( an Austro-Flamm Integra) required another very expensive repair, the Wiseway, with no discontinued circuit boards and expensive sensors, seemed like the way to go. The set up was simple. It was a one for one swap with the stove we had on the first floor (it and it's noise moved to the basement). The Wiseway does have quite a learning curve to operate. I work from home and good and bad I'm always trying to "dial it in". It is higher maintenance than the other two stoves. It runs best clean, so while you may not have to clean it as often as I see fit the performance suffers.
For the most part our stoves are running 24/7 and I clean the Wiseway daily (a whisker more than a bag a day). Our former consumption was about 8 tons/ year. It's looking like the Wiseway will be helping reduce that amount. The heat production seems fine. Without a blower, we're playing with fans to move the heat around. The burn back issue is significant although experience with how the stove works will help with this. We have only had some smoke, no fires. I have found that balancing the "after-fire" air of the chimney and the "pre-fire" air of all the many in take points, is the key to smoke free operation. The Wiseway appears to take in to much "pre-fire" air and gives heat and smoke the tendency to rise into the pellet supply. In the manual Wiseway mentions adjusting the (primary air flow{ their term ], pre-fire air { my term } by moving the secondary burn plate out for more air, in for less. The problem with this is there is an intake port, that can be attached to an outside air supply, that enters this area at 90 degrees causing all sorts of turbulence and to much input. In my situation I can't access outside air and found if I place a pellet pipe clean out cap over the intake port it creates much better linear flow of pre-fire air over the burn basket, makes the secondary burn plate adjustment much more effective, and tips the balance drawing smoke and heat down towards the burn basket and up the chimney. Sorry for the length of this. Looking forward to questions.
