Ok, Fellow Burners, I Too Purchased A Wise Way Pellet Stove, I Had A Good First Burn, 650 Degrees, About 14 Hours On A Bag Of Cubex, Went Out Of Town 5 Days , Came Home Fired Up The Wiseway, Found It To Be Lazy,Would Not Go Over 500, Poked And Prodded The Ashes , Went To Bed , Next Morning Went Into My Basement, And Guess What, BURN BACK, It Was Smouldering Right Up To The Bottom Of The Hopper, Temp Was 150 At The Guage, Shut The Fuel Off, Removed The Secondary Burn Pot And Pushed The Black Smoking Pellets Into The Ash Pan, About 6 Times, Before I Got It All, Smoke Detectors Billowing, My Wife Asking Whats Going On, I Think My Wise way Days Are Over, Have A Call Into The Factory, Something About Sealing Them Up??? , Not Convinced, I Think Its Going Back, ,,, I Should Have Bought Battery Back Up For My P68, And It Would Have Been Less Money For Sure,, I Got Very Wise In A Different Way, This Stove Is Hooked Up To A 22 Ft Masonary Chimney, With Outside Air,,, Just To Let You Know,, And I Have Been Burning Wood And Pellets For About 30 Years Now,,Cool.
first of all,Ok, Fellow Burners, I Too Purchased A Wise Way Pellet Stove, I Had A Good First Burn, 650 Degrees, About 14 Hours On A Bag Of Cubex, Went Out Of Town 5 Days , Came Home Fired Up The Wiseway, Found It To Be Lazy,Would Not Go Over 500, Poked And Prodded The Ashes , Went To Bed , Next Morning Went Into My Basement, And Guess What, BURN BACK, It Was Smouldering Right Up To The Bottom Of The Hopper, Temp Was 150 At The Guage, Shut The Fuel Off, Removed The Secondary Burn Pot And Pushed The Black Smoking Pellets Into The Ash Pan, About 6 Times, Before I Got It All, Smoke Detectors Billowing, My Wife Asking Whats Going On, I Think My Wise way Days Are Over, Have A Call Into The Factory, Something About Sealing Them Up??? , Not Convinced, I Think Its Going Back, ,,, I Should Have Bought Battery Back Up For My P68, And It Would Have Been Less Money For Sure,, I Got Very Wise In A Different Way, This Stove Is Hooked Up To A 22 Ft Masonary Chimney, With Outside Air,,, Just To Let You Know,, And I Have Been Burning Wood And Pellets For About 30 Years Now,,
Gravity Feed Stoves in White River Junction, VT. I also sell the stoves in Rutland, VT.Who is your dealer pellet powered?
hee hee "Burn Back" if you have to rename a understood term thats a bit troubling..
It's funny how we substitute a word for one that we don't want to say. After a while everybody knows that the substitute word means the same thing and we have ruined another word (perhaps tainted is a better verb for that). Still, "retrograde" sounds better than "run away" and "burn back" sounds better than "hopper fire", but we all know what it means.In the service we were never allowed to use the word "retreat" it was always "retrograde". I use that word years after I was discharged and it still makes me laugh.
Ok, I Hear What You Are Saying, I Shot From The Hip And Should Have Thought A Little First, I Did Do Some Research And Found First What You Said, I Did Widen The Basket Some, Made A Big Difference, I Have A Draft Regulator Coming To Adress The Chimney , I Am Burning It Today And I Will Say Its The Only Source Of Heat On And My House Is At 72 Degrees Upstairs, I Am Going To Shorten My OAK As Well, As Far As Pellets Go I Also See That They Are Making Or Already Have Made A Hardwood Pellet Basket ,My Dealer Had Limited Knowledge Of This Stove, I Did Research It A lot Before I Bought It, I Believe I Can And Will Make It Work For My Application , Sorry If Offended You , Like I Said , Shot From The Hip, I Do Believe In These Units, I Am Located In The Mt Snow Region Of Vermont ,Knowledge Is Power And I Was Lacking Some, I Think I Will Be Sorting This Out Myself,,,,,,,,,first of all,
In my humble opinion and limited knowledge, your 22 foot chimney is way too tall to support a proper draft. I also would not recommend a basement installation for the WiseWay- that's just me. The Wiseway works best with an 8 to 15 foot chimney- it does not list that fact in the manual because professional installation is encouraged however, I have seen online resources that state that fact. If you told them your chimney was 22 feet, they shouldn't have sold it to you or they at least should have given you the facts. Also, the Wiseway burns softwood pellets best. They all burn Douglas fir pellets out west where the stove is made. As for myself and others here in New England, we have had great luck with Vermont Wood Pellets and Barefoot Pellets out of PA. I don't know where your from so I don't know what brands are available to you. You could also try adjusting the spacing in the primary burn basket as this will produce more heat and possibly adequate draft. I spaced my basket so that it just barely fit into the primary chamber and it made a big difference. So far, the WiseWay has kept my house at 70 degrees without the help of fans or other appliances. It's been in the teens to low 20s outside. Burning just barely over a bag of Vermont Wood Pellets a day! Vermont Wood Pellets are Super Premium pellets with less than .5 percent ash and are made 10 minutes from my house. So, conveniently, I have an ideal fuel for the Wiseway close by. The main thing here is customer support. I hope you purchased the stove from a dealer that will help you sort this all out. I know I did and I don't know where I would be without them!
> In your photo, you show the fire extinguisher next to the stove. NEVER put it next to where you expect a fire! You don't want to run INTO the fire to GET the extinguisher! Put it across the room, so you can run to the fire WITH the extinguisher.
Funny, I Thought The Same Thing, I Sealed Some Openings Around The Feed Sleeve, And Added A Hopper Gasket ,Actually From A Harman P68, And So Far So Good, They Are Supposed To Be Sealing Up The New Ones ?? Great Stove, It Is 72 In My Home , Its -1 Outside , Its The Only Heat On Right Now,, And Its In The Basement,,Since I am always a sucker for the oddball, unconventional stuff, I've been following the Wiseway posts and their forum. One thing that struck me as curious was the fact that the hopper lid is not gasketed and sealed, which would prevent burn back since there would be no oxygen up there. My old gravity fed coal stove, a Franco Belge, has a heavy cast iron lid with a gasket. The coal ran down and out onto the burning bed of coal as the bed burned down. No possibility of a burn back. Why wouldn't they do the same thing to the WiseWay?
To the OP> In your photo, you show the fire extinguisher next to the stove. NEVER put it next to where you expect a fire! You don't want to run INTO the fire to GET the extinguisher! Put it across the room, so you can run to the fire WITH the extinguisher.
No, you did not offend me. I just want to make sure the FACTS are out there as this is an amazing stove.Ok, I Hear What You Are Saying, I Shot From The Hip And Should Have Thought A Little First, I Did Do Some Research And Found First What You Said, I Did Widen The Basket Some, Made A Big Difference, I Have A Draft Regulator Coming To Adress The Chimney , I Am Burning It Today And I Will Say Its The Only Source Of Heat On And My House Is At 72 Degrees Upstairs, I Am Going To Shorten My OAK As Well, As Far As Pellets Go I Also See That They Are Making Or Already Have Made A Hardwood Pellet Basket ,My Dealer Had Limited Knowledge Of This Stove, I Did Research It A lot Before I Bought It, I Believe I Can And Will Make It Work For My Application , Sorry If Offended You , Like I Said , Shot From The Hip, I Do Believe In These Units, I Am Located In The Mt Snow Region Of Vermont ,Knowledge Is Power And I Was Lacking Some, I Think I Will Be Sorting This Out Myself,,,,,,,,,
That's right. All of the current stoves out there are sealed as far as I am aware. All of the stoves I have installed were sealed. I'm not sure why yours wasn't.Funny, I Thought The Same Thing, I Sealed Some Openings Around The Feed Sleeve, And Added A Hopper Gasket ,Actually From A Harman P68, And So Far So Good, They Are Supposed To Be Sealing Up The New Ones ?? Great Stove, It Is 72 In My Home , Its -1 Outside , Its The Only Heat On Right Now,, And Its In The Basement,,
BTW- Nice to make your acquaintance fellow Vermonter! If hardwood is your only option, you can try the hardwood basket. I have one if you want it. Personally, I think finding a super premium softwood is the much better option.Ok, I Hear What You Are Saying, I Shot From The Hip And Should Have Thought A Little First, I Did Do Some Research And Found First What You Said, I Did Widen The Basket Some, Made A Big Difference, I Have A Draft Regulator Coming To Adress The Chimney , I Am Burning It Today And I Will Say Its The Only Source Of Heat On And My House Is At 72 Degrees Upstairs, I Am Going To Shorten My OAK As Well, As Far As Pellets Go I Also See That They Are Making Or Already Have Made A Hardwood Pellet Basket ,My Dealer Had Limited Knowledge Of This Stove, I Did Research It A lot Before I Bought It, I Believe I Can And Will Make It Work For My Application , Sorry If Offended You , Like I Said , Shot From The Hip, I Do Believe In These Units, I Am Located In The Mt Snow Region Of Vermont ,Knowledge Is Power And I Was Lacking Some, I Think I Will Be Sorting This Out Myself,,,,,,,,,
Thanks Webbie! I agree. What I believe will make or break this learning curve is customer support. Just like those catalytic stoves you mentioned, pI'd say the proof will be in the pudding when 500 or more are out there in various installations and 95% of them work fine.....might take some time, though.....
Until then, it's going to be a learning experience. Trying to regulate chimney draft (or height, which only relates to one small part of draft) is a VERY difficult proposition! Way back when the first catalytic stoves were sold, I talked to the engineers that designed them...and they also said that a certain exact range of draft was required to make them work best. Of course, when they didn't work perfectly, they didn't burn back! So that's a different story....
Even the same chimney will vary vastly in draft based on the weather, the wind, the stack temp and other factors. This is one major reason that most pellet stoves use fans...they can regulate the draft....
Sure, it's possible that a stove like this can and will work. But it's not as simple as it sounds.
All the WiseWay stoves I have installed have been installed with barametric dampers. It is my understanding that this is highly recommended to all stove dealers and owners. A traditional damper is discouraged by the manufacturer so the barametric is the only logical solution. Any dealer not passing this information along is to blame for any runaways. Also regarding hopper fires, all current stoves being shipped from the manufacturer now have seals installed so that there is no oxygen in the hopper area, thus eliminating the possibility. The reason why that was not done originally, and this is direct from the manufacturer, is that they never had a burn back issue until the stoves were sold on the east coast and people started burning cheap hardwood pellets in the stove. Softwood pellets and sealed hoppers make things so much simpler. Also, by design the hopper area was originally left unsealed so that a stove owner could easily remove the hopper and heat shield and install a second water heating jacket on the back side of the stove. Of cours, Once that was done, the hopper and heat shield is reinstalled. Now the owner will have to reseal the hopper area as well.Barometric Damper maybe?
We have run a pellet stove in the basement and one on the first floor, fairly centrally located, for about 4 years. . We spend a lot of time in the same room with the first floor pellet stove and the noise problem was significant. When the downstairs stove ( an Austro-Flamm Integra) required another very expensive repair, the Wiseway, with no discontinued circuit boards and expensive sensors, seemed like the way to go. The set up was simple. It was a one for one swap with the stove we had on the first floor (it and it's noise moved to the basement). The Wiseway does have quite a learning curve to operate. I work from home and good and bad I'm always trying to "dial it in". It is higher maintenance than the other two stoves. It runs best clean, so while you may not have to clean it as often as I see fit the performance suffers.We use essential cookies to make this site work, and optional cookies to enhance your experience.
