Theo said:Same problem. New Montpelier insert, full chimney liner, blocking plate, dry wood. When I start it, it takes 1-1/2 to 2 hours for the thermoswitch to turn the fan on, and it still kicks off occasionally even with a big fire going.
Had some other problems from new, and dealer was VERY unhelpful - they don't get paid much for service. I finally got them in to fix other issues (like a broken air slider control), and they replaced the thermoswitch. Same result.
I've measured the blower air. It's never much above 140F no matter how hot the fire. House is about 1500 sq.ft., and in stove can only raise the temperature by about 30 degrees. That clearly isn't going to work when it gets well below freezing. 1978 stove I had before could easily turn the house into a sauna in a couple of hours; I replaced it to get an overnight burn and more efficiency.
Dealer and installer no help, factory won't talk to owners. This is my primary heat source, and I'm in a bit of a panic. I'm wondering if it's possible to mis-assemble the stove (say, firebrick in wrong, or a plate out of place) so that heat can't get through to the air ducts? There is clearly something seriously wrong. The only way I get useful heat is with the door open - inefficient and not very safe! And almost no heat with the blower off.
If anyone has an idea, I will be VERY grateful.
Thanks-
Theo
Hey Theo - If you read Lynn's comments above, you will see that most of the issues are operator/operational issues and not the manufacturer - not to discount the fact that you may be getting crappy service.
If you do indeed have a snap disk issue, it is most likely the location [should not be in the path of air flow] and that it is not pressed up against the stove. You should be able to check those out DIY. The long and short is that i think the problem may be is that you are just not burning hot enough.
