@samdweezel05 I got all hung up on wanting to a real simple horizontal out and just kept running with it. Thats the main reason there is no up/out or out/up... I have a generator to run the stove during a power out. I assume this will handle the "smoke in the house" from a power outage. If it all goes to heck, then I will scrap my current proj and do an up/out install... probably muttering "they were right" the whole time!
If the stove looses power, then the stove fire dies and the stove fills with smoke. If there is no OAK, then the room fills with smoke!
The up and out provides enough draft when there is no power to remove the smoke from the stove and the house properly.
When doing an outside vertical the cold temps and dampness get in the pipe to clog it up much more often. That is why the interior up and out is the most recommended install.
Also if the outside vent termination was above the window, rather than below the window to the left like it is, then it would be code acceptable being 1 foot above the window.
Of course if the stove was ever changed out, and another stove put in the same place, an adjustable pipe could be added for any difference in the stove's vent flange height. In the straight out install you have to change the hole in the house. I just plugged a hole like that yesterday and put in an up and out kit. The vinly siding was black, the soffit was black and the new stove flange was higher than the old stove flange. Therefore I installed an up & out kit.
The straight out install can spit hot embers that cause fires sometimes too!
Also you must go out from the house far enough so the house will not get black from the smoke. If there is a ventilated soffit above the vent termination you should come out beyond that also so smoke will not get in the attic!
Just my experience.
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118144-552957bac9b8357f5f979eb986395172.jpg?hash=2IZMipwr_S)
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118145-0d48e56c9ff020774b2624359a8e5255.jpg?hash=j4zzfmUKJf)
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118152-e82565db18f8ca57f2a8103e0d6039e2.jpg?hash=VlpUfGs2Q-)
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118151-e2897e6909c9d55b48667c39d5889be2.jpg?hash=HlwhWFigVo)
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118150-46eb35422494d3b5ff9c2b7864884b8f.jpg?hash=j0iWTW1gur)
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118149-507fe3d0fec7a397a1e4ce6e8f2f97d5.jpg?hash=v6IgWprYWD)
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118148-ca71a977ad37de76dde487c6e23a4c7d.jpg?hash=sGKmJUGasG)
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118147-58fa8f74e132c817dec6c5ea294d7337.jpg?hash=F5f70ZCVTy)
![[Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out [Hearth.com] My Install of Harman P-43 w/ Selkirk Direct Temp OAK, Horizontal Out](https://www.hearth.com/talk/data/attachments/118/118146-987bc61d2c3770842f2fede6e38acd31.jpg?hash=HR3ATSbqK4)
