The fact of the matter is that no matter how much advice someone has about the neverburn system, there appear to many applications for which this system won't work. We can sit here and talk about coal beds, draft, seasoned wood, outside temperature, etc, etc, but the fact of the matter is these neverburn stoves appear to need "perfect" conditions to work. Apparently, I don't have "perfect" condidtions, and neither do many (if not most) other people. Nor do I always have time to rush in to get fresh wood on before the required 6" coal bed burns down 1/4" too much, necessitating a complete cold start procedure.elkimmeg said:It just occurred to me all stoves stall secondary combustion when the temperatures fall below the ignition point of smoke. whether you have top tubes or secondary combustion chambers
I think some of the issues is weaker draft this time of year I also think the primary air control is cut back to much in weaker draft situations and when it stalls it is telling you it really needs more combustion air add it I bet it starts again.. I notice wood quality I need more primary air in this part of the w burning season. last night upper 20 again I grabed wood seasoned one year
I had to open the air up a bit more and waite a bit longer before engaging secondary combustion. I'm so spoiled using 3 year old seasoned wood I forgot what it was like to use only 1 year seasoned wood. Much harder to obtain results the stove does not function nearly as responsive. The difference is really noticable.
