S
ScotO
Guest
yep, run the saw wide open, slowly back off the "H" screw til you get max RPM, then keep backing off the "H" screw til you get the 'flutter' or 'two-cycling'. Good to go.....you always want a little two-cycling to keep the cylinder from being leaned out when you are making the cut.....
