ericm979
A Ratio-Rite makes getting the correct ratio easy and you won't be limited to oils that come in certain size small bottles. Many high quality oils only come in quarts or liters or gallons.
You measure out oil in a calculator?!So does a calculator.
Do it in liters. It’s simpler. 1L /xx where d is your mix ration. xx:1. 32:1. 1/32=0.0312L or 32 ml. 4 liters Call it 120 ml of oil.
50:1. 1/50= 0.020 or 20ml per liter of gas. All our new cans are graduated in both freedom units and metric.
Now, there's a guy with some common sense!Use your 2.6 oz oil...just use the fuel pump to dispense .8 gallon into the can...40:1
Many folks including myself, buy and store ethanol free for power equipment. It may sit for a few months. Octane does drop as gas ages so it makes sense to me to buy the higher octane ethanol free.
On average though, there are a whole bunch of people out there paying for octane that they just don't need...oil companies have done a very good job of brainwashing people that they "need" premium (look, even the name is marketing!) fuel for various reasons...then there is the old wives tale that it gives you more power too
Not mine. Just re-checked my manuals to be sure my memory wasn't drifting, and both of my Stihl manuals say 90 mininum. This is an 064 (85cc) and 036 Pro (63cc), both late 1990's / early 2000's vintage.Stihl says to use 89 octane in their saws. At least the four that I own.
Yep. As noted above, I always run a few gallons of 93 into the car, to purge the line before putting the nozzle into the 1 gallon can. I'm not sure what those pump nozzle lines hold, but assuming 15-20 feet of Ø5/8" line between mixing valve and nozzle, it's likely 0.3 gallons.If you're pumping from a blender pump (which is nearly all that I see these days), the first half gallon or so is whatever was pumped last. If you're pumping 10 gallons it's not a big deal but if it's 1 gallon, it is.
