MORSO 7110 BACK WALL LINING FIRE BRICK CRACKED
rtaichman
1
new york
hi my names robert. I have a morso 7110 that was installed in our vacation home about 4 years ago. We use it pretty sparingly maybe once every 2 weeks in the winter and fall so dont get a whole lot of use but we use it every time were up at the house. I recently noticed that there is a hairline crack on the back wall on the firebrick as in the photos attached. Is this common on these types of stoves. I was told by the distirbutor that it is quite common and nothing to worry about only if it starts to crumble it should be replaced? is this true? im a bit nervous to continue using it should i replace it?
does anyone have a video of how to replace the back firebrick wall and perhaps a link to the replacement brick for this model?
thanks
  • [Hearth.com] MORSO 7110 BACK WALL LINING FIRE BRICK CRACKED
Reactions: DAKSY
Looks like you’re going to have to buy the entire refractory kit. Take a look at the pieces on your unit & you should be able to figure out which piece has to come out first. Generally, the sides hold the back in place, but you’ll have to look to see if that’s how yours has to come apart. Not intending to belittle or disrespect you, but make sure the stove is cold before you start.
I'd use it like the dealer recommended. So far the bricks look in very good condition and appear to be held in place well by the side bricks. The crack could be mended with some refractory cement if it's worrisome, but this isn't a bad case. Be careful adding wood into the hot stove so that it doesn't bang against the refractory bricks.
