Some said the "Denniswood" was 6% or less last fall. We did not notice any problems when it was placed in two different stoves.
Backwoods Savage said:Some said the "Denniswood" was 6% or less last fall. We did not notice any problems when it was placed in two different stoves.
Backwoods Savage said:Several tested it with MM and then Battenkiller went to work with his "scientific analysis. There were some interesting results if you care to go back and read the posts. Some MM could not get a reading. Some got 6% some got higher, etc. I simply said it was dry and would burn nicely.....and it did.
Did you click the link I posted, BK checked with with a MM and also weighed it and it was not 6% by any means.cptoneleg said:Backwoods Savage said:Several tested it with MM and then Battenkiller went to work with his "scientific analysis. There were some interesting results if you care to go back and read the posts. Some MM could not get a reading. Some got 6% some got higher, etc. I simply said it was dry and would burn nicely.....and it did.
Ok thank you
krex1010 said:Valhalla said:You would not want moisture in the gasoline for your car, diesel fuel for your truck, your home heating oil, etc.
So why accept any moisture in your wood stove fuel!
Actually fuel wood can be too dry. When mc starts getting really low, like below 8% the efficiency of the burn actually starts decreasing. Although i will say that in almost all areas, firewood that is seasoned outdoors will likely never reach those low numbers. 10-20% mc is the sweetspot for woodburning.
I get it BWS, you hate MM's and nothing isnt going to change your mind, when a new wood burner comes on here and needs to find some of the dryest wood he can as quick as he can a good bit of advice is a MM, they work well as most posts about them agree, not sure what you are talking about with the bad readings. So we like to give good advice to newbies and all your doing is raining on the parade. As far as this subject is concered I'm out.Backwoods Savage said:Should everyone do that? :-/
Came in handy for me this year. Everyone I supply was about out of wood, and I got a late start splitting and stacking for this season. I cut mostly dead or dying trees, and the meter allowed me to separate drier sections of the trees into stacks for 2011 and leave the rest for 2012 and beyond. Trying to separate all of that stuff by feel is harder to do and the sound can fool ya sometimes...oldspark said:when a new wood burner comes on here and needs to find some of the dryest wood he can as quick as he can a good bit of advice is a MM
oldspark said:I get it BWS, you hate MM's and nothing isnt going to change your mind, when a new wood burner comes on here and needs to find some of the dryest wood he can as quick as he can a good bit of advice is a MM, they work well as most posts about them agree, not sure what you are talking about with the bad readings. So we like to give good advice to newbies and all your doing is raining on the parade. As far as this subject is concered I'm out.Backwoods Savage said:Should everyone do that? :-/
krex1010 said:CTYank
Wood cannot be too dry to burn, yes wood that has under 5% mc will take off and burn like a freight train. The issue with super dry wood is that it doesn't burn clean. Off gassing occurs so quickly that secondary combustion cannot keep up and gas and particulates are forced up your flue. Those gasses and particulates are potential fuel that is lost. Yes those lost btus will have to be weighed against the btus required to vapors the moisture in slightly wetter wood. But that slightly wetter wood ( and I am talking about wood in the 8-20% mc range) will have a more complete combustion and will foul your chimney less than wood with mc close to zero. Super dry wood also greatly increases the risk of overfire in your stove. I believe most manufacturers warn against burning the amounts of super dry wood. I will look for some documentation to back up what I am saying.
cptoneleg said:krex1010 said:CTYank
He is the one in the past that says he burns 0% moisture wood- says he brings about 3 weeks worth and sits around stove- I say wheres the pictures???
They just spent at least $2000 on a stove and chimney, they'll just have to wait an extra day to break even burning wood. :smirk: Or they might save themselves a lot of headaches that first year by using the meter to obtain some burnable wood. They might even be able to find some dry dead wood that they can use and avoid buying as much the first year, recouping the outlay for the meter. I'll still use mine to see if I can burn stuff that I've just cut, even though I already have dry wood for next season, in case it's something different (what's the hearth record for different species burned in one season?) :cheese: And I'd like to see how good I can get at estimating dryness in different woods, as I cut them or in the stack. :coolsmile:Backwoods Savage said:they won't even have to spend extra dollars on a meter.
I can send you a PM but I am not stretching anything and I think my posts bear that out.Backwoods Savage said:Please do not stretch it any more. Just read what was written and what has already been posted on this forum many times. What has been written is already enough and we do not want this to turn into a pissing match nor do we want the moderators closing this thread. They already have twitchy fingers.
