Minimum Hearth Pad Depth for Stove
sesro1978
133
Vermont, USA
Hi-
I've been lurking for a while and at a point where my family is considering a smaller stove for our home. A concern we have is that our house, being smaller, has some space limitations. We have been looking at the Hampton H200 and are having a hard time figuring out what size pad (depth-wise) we will need. We are doing a corner-install, so the dimension we are looking at right now is the depth from the corner to the front of the pad.
The manual seems to say that this depth in the US is 43" minimum, with a minimum width of 36". The dealer is telling me 60" from the corner to the front of the pad, which seems to contradict the H200 manual, unless I'm reading the section on Floor Protection incorrectly.
Anyone out there have one of these stoves installed in a corner with floor protection? If so, what is the pad size? Any help here would be greatly appreciated as it's a real sticking point with my significant other (given the small-size of our home).
Related, would there be anything we could install that would reduce the need for a potentially 60" pad? Wall protection maybe?
Thanks!
Hi-
Thanks!
I dont beleive you can reduce clearances anymore on hamptons. But just look up the manual it will have all of the information you need
The measurement may be 60" from the corner to the front, but the pad doesnt go all the way into the corner. Looks like 36x43 minimum to me, and it needs to be floor protection not just ember.
Corner installs take up the most floor space, a stove with its rear parallel to the wall takes up the least amount of space
My guess is the difference is 43 x 36 is the minimum freestanding, 60" is for a full depth hearth pad to the back of the corner to the front of the hearth.
Minimum Hearth Pad Depth for Stove Minimum Hearth Pad Depth for Stove
View attachment 227108 View attachment 227109
Ok, yea, I can see that...I don't think I was reading the manual correctly. I think maybe by simply changing the orientation of stove might solve our space issue.
Yes. The pad does not have to go into the corner, but it sure looks better if you did that.
