Maybe in the earliest stage of the fire but...Warren said:Marty said:It seems to me the real big advantage of masonry heaters is in the reduced pollution and more importantly, fuel consumption. Although the eaiser tending characteristics are highly desireable to be sure.
It is a wonderful thing that wood/corn/pellett burners use local sustainable energy sources that do not fiddle with the atmosphere's natural cycles, but if the percentage of them were to increase to any appreciable degree we would be faced with polution and fuel scarcity problems that far exceed those that origionally led to the masonry heaters development.
Easier tending? Many people consider starting fires a pain... Isn't having to start 2 fires every day and gather kindling, paper, etc... to start things a bit of a pain vs just tossing splits into a running fire every so often?
you don't have to regulate fuel and air to produce even heat... just charge up the battery and let it release... also cuting splitting stacking and halling six logs instead of ten means less work directly associated with 'tending'.
