No..you can get the stove to transfer more heat by blowing across it..I agree with that.SolarAndWood said:HotCoals said:Just leave the t-stat out of this..I'm talking blowers blowing across a stove with out a thermostat.
Yep, the tstat adjusting the air is the only reason this makes a difference. Without it, the stove would simply run cooler if you did nothing other than turn the fans on.
Or are you saying that you can't get the steel to transfer more heat just by blowing air over it?
I guess a misunderstanding ..i was not including the t-stat in the experiment...which would be all most impossible to do with a BBK...maybe turned all the way up..but I don't want to melt my steel! lol.
The colder the room relative to the stove the more it will transfer also...but the fire won't change..without a t-stat anyways.
