So I posted this in here but didn't get far with it hoping I can get some advice with this post.
I had a wood burning insert (that pervious owner changed to a vc wood stove but left insert) it seems to have a 12 inch outer liner and a 8 inch iner ( not sure what that's called perhaps "Coaxial pipe" ) In any case I Am told it should be changed out to Class a double-wall all-fuel pipe. So I plan to buy class A double walled. Take out the existing 8in leave the 12 inch and run the new 8 inch inner dim double wall pipe though the 12. Also I plan to cut the granite Like so
![IMG_1590 lined up.jpg IMG_1590 lined up.jpg](https://www.hearth.com/talk/data/attachments/298/298947-b71a8e496615d2aa2ee54816734049c8.jpg)
Black lines I will cut then the top 2inch thick 24" wide granite top plate will go on floor in front.
The red x I will be removing all the wood so that it sits at the same height as the current floor. Then adding cement bored ( durrock or the like) to the back and sides then I was thinking a one inch mettle spacer then anther 3/4 thick durrock. Then ether granite block to match the rest of the fireplace. Or open to ideas? The floor I was planning on using the same granite stone to match.
After all that I am going to try and get my hands on a Blaze King 40
The whole point of this was to make it safer then how they had it with a better stove. All add a few older pics of how it was set up. TYIA for help
![IMG_9067.JPG IMG_9067.JPG](https://www.hearth.com/talk/data/attachments/298/298948-b60931944aef3ea8709c0c9fafb82395.jpg)
![IMG_9069.JPG IMG_9069.JPG](https://www.hearth.com/talk/data/attachments/298/298949-4496d93c9c85d4196f3f3dd41cfe53a9.jpg)
![IMG_9070.JPG IMG_9070.JPG](https://www.hearth.com/talk/data/attachments/298/298950-f440583bfbfd34662a8a6e4595c871a7.jpg)
