I just finished installing my Thermopex line from my outbuilding (where the Seton resides) to the house. I plan on connecting the lines to the existing loop (radiator heat) so that my existing oil heating system (Burnham Jubilee) can act as a backup. The Seton came with a few items (Taco 008 pump, air vent, temp. & press. gauge, drain valve, fill valve, two aquastats, pressure relief valve, check valve, expansion tank). My concern is that I do not have domestic water running to the outbuilding for the expansion tank. I'm having trouble visualizing where the make-up water will come from when it is needed and where that expansion tank will go. I am going with a pressurized system using a 30 plate heat exchanger (if that helps).
-Any diagrams would be great, thanks.
