Is it necessary to install a boiler low water cutoff in an EKO-60. How is it connected and what does it do when the boiiler water gets low? Also, is it better to use the  built in overheat protection, the one that uses an automag and cold domestic water to cool off the boiler, or plumb in a heat "dump" load like a couple runs of baseboard heaters or a water tank whose sole purpose is to cool the boiler off if the power goes off for instance or a circulator pump fails.
I started plumbing tonight. I have the shed built, two five hundred gallons propane tanks are installed. I plan to run pipe from the EKO-60 to the propane tanks and then back to the EKO-60. (A small loop is built in at the boiler with a danfoss to provide return water protection. ) I will run from the propane tanks to the a heat exchanger and from the heat exchanger to the oil fired boiler. I will install two closely spaced "tees" on the oil fired boiler inlet or cold water return side. If the zones call for heat, the oil boiler circulator goes and sucks the hot water from the propane tanks into the oild boiler and then out to the zones. I use the heat exhcanger because the oil boiler system has glycol. The propane tanks will have water.
Also, what kind of water treatment solution should I put in the propane tnaks. They are a bit rusty on the inside....
Mark in Alaska
Mark in Alaska
