Hey Clay,
I have a Breckwell Big E and have burned about 18 bags in it so far.
I'm now burning Maine Woods pellets. I have ~30+ bags left and will go thru those before I burn the 2 tons of Lignetics I have stored in the breezeway.
The Maine Woods are 80/20 hardwood/softwood and are smaller than the LG's. Also quite a bit softer. I can break the MW's with my thumbnail fairly easy but the LG's are alot harder.
I burned a few bags of the LG's before I bought the MW's and found they leave much less ash and no clinkers.
The Maine Woods leave a big clinker every 24 hours. I've tried adjusting the damper, stiring the burnpot a few times per day, etc., but the clinker still shows up.
So I've concluded in my case it's the MW's pellets.
I've been told that clinkers are due to moisture in the pellets and that there's no way to tell if the pellet manufactures had stored their pallets outside or not.
They are covered up either way but there's really no way to keep out the moisture when they are outside for a long enough period.
The MW's also dirty up the glass quicker.
FG.
clayfist said:
Forum and pellet stove newbie here.
I installed our Lopi Leyden pellet stove early Oct. Went through the auger issue and was eventually told to remove the flapper in the chute as well. I didn't really like the idea of completely taking it out so I modified mine. I cut the stationary door off and left the flapper door on then reinstalled it.
I have since went through a ton of pellets (we use "green supreme" from Canada) and have been recently having auger jams. Not sure if it's from the dust or perhaps I'm loading the hopper to full.
Other issues with the stove I'm experiencing are clinkers when I burn on the high setting. I've tried to adjust the air intake but I guess I'm just not sure if its were its supposed to be. And last while cleaning the stove I removed the brick to clean behind it and it crumbled in my hands. It seemed to have been cracked around the hole for the chute.
I'm hoping that most of this is user error and I will eventually get the hang of it. Any thoughts or suggestions would be appreciated.
