Oh ya! Kinda like an unpredictable bomb right in the middle of the house!yea mine did that too. Would push the top load door up
Yeah it only happened to me on a low burn. Maybe a clogged chimney would do that but I am no expert
Jonathan70, how tall is your chimney? Just curious to compare what mine will preform like. 17' tall from stove with 2, 45 elbows just below ceiling.
Just want to know if I'm gonna have any draft issues with the cape cod with this flue.
Thanks
  Gave it a good brushing and had no problems on the next fire.  It's also running much hotter.  Might be worth taking a look if you're seeing smoke from the bypass when shutting down the intake.Both. In the history of cat stoves, the shortest lived have had little to no cat protection. Stove manufacturers put lots of R&D into preventing premature cat failure. They do their best to prevent flame impingement in front of and also behind the cat. The Cod has no protection on either side. This has proven in the past to be an issue for other manufacturers.With this design what are the potential problems that can arise Webby?
Dusty cat with ash? Shorter cat life?
No,Yes me too! Very interesting. Are other Cape Cod owners having cat issues? Hope others chime in.
Webby, while you had your cod did you have any cat issues?
Again though, why would Lopi choose to use an inferior design given what webby3650 shared as what it seems to be common knowledge among woodstove builders/designers? Meaning, what do you think the pay off, advantage, is for them not including a deflector/protector?
