Pellet-King said:The price of pellets makes it not worth it, factor in the cost of the stove, installation, pipes and pellets you can burn oil/gas for many years to recoup, it's all a monopoly and i'm not buying until pellets are under $200, rather i'll use my stove as a conversation peice.
All you people here dont be fools!!
Clay H said:Unless your stove can burn rabbit pellet, good luck seeing them go under 200Pellet-King said:The price of pellets makes it not worth it, factor in the cost of the stove, installation, pipes and pellets you can burn oil/gas for many years to recoup, it's all a monopoly and i'm not buying until pellets are under $200, rather i'll use my stove as a conversation peice.
LMAO....even with pellet prices at 5.40 a bag (295.00 a ton) I will save alot of money over propane which is my only other option.
I use 2.5 tons to heat the house entirely for a season...thats 737 bucks. If i was using propane at the current price (which always goes up around Dec.) i would spend 350-400 a month - around 1500-1600 for the season.
I don't think i'm a fool.
Clay H said:Pellet-King said:The price of pellets makes it not worth it, factor in the cost of the stove, installation, pipes and pellets you can burn oil/gas for many years to recoup, it's all a monopoly and i'm not buying until pellets are under $200, rather i'll use my stove as a conversation peice.
$1100 for 4.5 ton of eagle valley great find for a great pellet IMOamick780 said:Clay H said:Pellet-King said:The price of pellets makes it not worth it, factor in the cost of the stove, installation, pipes and pellets you can burn oil/gas for many years to recoup, it's all a monopoly and i'm not buying until pellets are under $200, rather i'll use my stove as a conversation peice.
Clay H,
I agree with you, my option to pellet heat is Propane, to heat my home to the same temp as pellets would cost me almost twice the amout of pellets. Even with a brand spanking new Rheem 2 stage 95% effecient furance I am looking at $2000 + a year for propane vs. my $1100 for 4.5 tons of pellets. 3 year old well insulated house.
ineclipse said:slls said:Last winter I burned 35 bags and 300 gal #2 oil, 1500 sq ft, well winterized.
And you say you live in central Maine? You must have taken a two month holiday in Florida or something.
Clay H said:How is your house insulated/winterized? I want to do what your doing!
slls said:Clay H said:How is your house insulated/winterized? I want to do what your doing!
6 inch walls 19 R, 12 inch ceiling 38 R, all doors and windows insulated. All doors and windows also have storm windows and storm doors, old habit. This is also running 70 deg F 24-7, turning down to me has no value, you just need to heat it up again.
When I moved into the house many years ago I could tell the temp outside from inside, not anymore, have to look at the outdoor thermometer.
Teddy1971 said:slls said:humpin iron said:sils please ck the btu out put of your central heat system, then the max btu output of your pellet stove...........do the math and report back to us as to how you thought the pellet stove would do your whole house
I never said I thought it would heat the whole house, I was just replying to all the [ how much warmer pellets are to oil heat]. Which is just BS.
SllS
I may have misrepresented my situation with my statement. You are correct that My house would be just as warm with oil as it is with pellets if I turn the heat up. What I should have stated is that I would have to spend more money on oil than I would on pellets to keep the house just as warm. I Heat a 2500 SQFT Colonial (72-74 Downstairs/ 67-69 Upstairs) with my stove. Even with oil prices down this year I will spend $1155 to heat my house with pellets (plus 300 Gallons of oil for Hotwater and the basement (800sqft)). I would easily use @ 1000 to 1200 gallons of oil to be just as warm which would equate to $2150 to $2580 at todays prices (2.15/gallon of oil). I myself don't want to go back to the days of not knowing where prices are going with oil. Granted pellet prices seem to fluctuate by not as extreme as oil. At least I have a choice now and am saving alittle money as well.
woodsman23 said:I fear some inaccuracy's in slls statement also. I have a newer (built myself) 1200sq ft home, very well insulated with r 21 walls, r 45 in ceilings, r 30 under floor all new windows and doors and propane would be out of the world (~1600-1700$) to heat to 72 degrees in the winter. I used 4 tons last year of pellets 24/7 and in the past 2-3 years my pellet stove has paid it self off with the money saved from not using propane. Total pellet cost was 925.00$ plus electricity...
mascoma said:Teddy1971 said:slls said:humpin iron said:sils please ck the btu out put of your central heat system, then the max btu output of your pellet stove...........do the math and report back to us as to how you thought the pellet stove would do your whole house
SllS
I have to call bull on the conversions here. 1000 gallons of oil would equal 8-10 ton of pellets. $1155 would only buy you 4-5ish tons. Something is amiss in your figures on one side or the other.
I went from 700 gal of oil and 3 cord wood in 2007-8, to 7 ton pellets and 100 gal oil 2008-2009. Didnt end up saving the money I planned on at $4.5gal oil but still very happy I switched and will burn pellets again this year savings or no.
Daves said:Well -- my local HD has Fireside Ultras for $299/ton. I won't be considering them even with their promotion since I can get pellets for $279/ton (such as Barefoots) and others for less.
investor7952 said:Daves said:Well -- my local HD has Fireside Ultras for $299/ton. I won't be considering them even with their promotion since I can get pellets for $279/ton (such as Barefoots) and others for less.
My local HD Just lowered the fireside ultras to 249 a ton .If you buy 2 tons take $50.00 off !$225 a ton for fireside ultras is a deal from last years 300 a ton.Also they have stove chow for 249.
If your willing to travel to waterbury, blazing hot stoves has barefoots for i think 290/tonDaves said:Went to my local Agway -- they had 20 bags of Barefoots on the floor. I asked how many tons they had (planning for when I was going to buy) -- they said they had 40 tons. I said I'd take 2 tons of the Barefoots. They said all we have is those 20 bags at $8/bag, but we have Bayou pellets for $279. Anyway, I bought a couple of bags of the Barefoots just to try them out in case they happened to get more in. Boy, the barefoots are nice! Very little fines, nice heat output. I have Hamer Hot Ones left over from last year, and I definitely like the Barefoots better.
Anyway, he made a comment that the pellet sales guys are all over Agway to take more pellets even though they don't need them... so maybe the prices will come down in the Northeast since oil/gas is more affordable this year.
Also stopped by my Home Depot -- They were selling single bags of Fireside Ultra's for $5 -- and Nature Best? for $299/ton. Their pricing didn't make sense since the individual bag rate was less than the full ton.
HEMI_1500 said:If your willing to travel to waterbury, blazing hot stoves has barefoots for i think 290/tonDaves said:Went to my local Agway -- they had 20 bags of Barefoots on the floor. I asked how many tons they had (planning for when I was going to buy) -- they said they had 40 tons. I said I'd take 2 tons of the Barefoots. They said all we have is those 20 bags at $8/bag, but we have Bayou pellets for $279. Anyway, I bought a couple of bags of the Barefoots just to try them out in case they happened to get more in. Boy, the barefoots are nice! Very little fines, nice heat output. I have Hamer Hot Ones left over from last year, and I definitely like the Barefoots better.
