I'll just add to my last comments, that those comments were on considerations when I made my decision.
After a couple of months of operation, I have a bit more appreciation for what lambda controls could add to operational efficiencies. For example, there are times when cold starting mine that I need to play with things until the thing gets up to speed. That depends on the wood I've got in it, how long its been since the last burn, the weather outside, etc.. I have found that sometimes, it takes quite a while for it to spool up - getting the coal bed established, the refractory & chimney up to temp, and a good draft going. Sometimes, the whole fire will almost go out when I close the fire door & the bypass. If that's going on, I crack the fire door just a hair to let more air into the fire box (primary chamber) until the secondary chamber & refractory gets up to temps & everything gets humping along like it should be. I also usually leave the ash door open a bit until I get up to speed. Mine is a very simple unit, with next to no air adjustments on it - it burns very well once it gets itself going, and it's sort of locked into tune for that. Getting up to speed, it could use some on-the-fly tuning adjustments.
