M
MasterMech
Guest
Got one sitting out behind the woodpile. Waiting for it's trip to the scrap yard. (Don't worry, it's an MTD! )Very nice More wall hangers!.....Just need a little splash of yellow and white.
Holy Deere's! You have a clear case of TAD.
Here's a slightly older one. I'm driving, younger brother is in the trailer.
Finally got mine all done and running. Since everyone else put up pics, guess I might as well. Here is a before and after. View attachment 106130View attachment 106131
Unless you want to see my dog or cat on it, nope.What? No kid on it?
You like that one? I have 16 more, This ones a 1976 Bolens H16 single cylinder overhead valve cast iron Tecumseh, running 25x10-12 ITP 589 rears and 4.00- tri-ribs up front, foot feed Hydrostatic transmission, with lock out posi-trac and all shaft drive, front mid mount and rear, and hydraulic lift. Nobody better get in my way, lol. I paid 500 for this (it didn't look like this) and a snow blower, tiller, deck and plow and I restored it last year. Cubs and Deere's run from this machineSchweet!
I just got a 1979 Yanmar 240. It is a little bigger than most of yours but I am really excited to use it this winter.
Has a 3pt hitch, PTO, 6 foot rear blade for snow removal, and a 60 inch belly mower deck.
Has taken 3-4 weeks for me to get it running again though but I got a steal on it at 1,000$.
Still needs more work though.
New battery, tire replacement (real beyotch), oil change, oil/fuel/air filter, new starter, serviced the fuel injector system, severely clean up the mower deck, find replacement parts, install a new mower belt also a real pain, front weights, lube and grease everything, Still gatta service the breaks, clean her up some more....
Overall pretty cool. My wife is determined I love the tractor more.... erhm... ehm.. uhmm...
I definitely cant keep my hands off it past few weeks for more than a few days or so though.
Sorry, chins = chains, Ags are Agricultural tires, or farm tires, plowing in reverse would mean (or should mean) that you will have to bend around backwards if you want to see what your going to hit or plow, not very comfortable for any period of time, you'll see. Wouldn't be hard to fabricate a front blade from a 54 inch John Deere blade. If the previous owner said he did not use chains on those tires in the Michigan winter, I would seriously take stock of everything else he professed to you. On a snow/ice packed driveway (flat or not) about the time you get a load of snow on the blade those tires will sit in one place and spin the same way your car would. Have you lived in Michigan long? When I was up there it snowed alot in the winter and often cars needed chains just to drive on the roads, and they weren't pushing a bladeHrmm by chins do you mean chains? and I don't know what AG are.
The owner recommended I plow in reverse with the blade backwards. He never used chains and had some small inclines to plow as well. My driveway is completely flat... so hopefully I won't need chains. We will see.
Those 425s are awesome vintage or not, we are talking serious machinery. Save your money on the FEL, they are useless on a GT, I had one on a 455, and on grass with a bucket of topsoil the machine was worthless, barely could reverse, turn and maneuver. FELs on anything less than 2500 lbs is all for show and piddlers, not saying they don't have a place, they do, if you have 1-5 acres they can be quite handy, just don't expect a lot, and figure if you use the FEL it will cut the life of your machine considerably, they are really hard on frames,, front ends, engines, and transmissions. I would NEVER buy a GT or small tractor that had or has a FEL for that reason, most of the time they look great, but they are whooped. Do you have the tires on the 425 "loaded"?Those are some nice tractors.
Here's what I have, although it's not exactly "vintage". It's a 2000 John Deere 425. 46" blower and 54" mower deck. I'd like to get the 3 point, rear PTO, and tiller for it, and also the FEL attachment, but we're talking $$$ for all that stuff. It's a great little workhorse as it is though.
I see 3 points out there very reasonably on craigslist, and sometimes you can sneak up on a good deal on ebay, if you had a 3 point you could buy or build you a little boom pole, 6 footer, they sell them on ebay for about a 110.00, with the blower on the front for weight you could haul some big rounds. I'll tell you a trick about loading the tires, take the tire off the tractor and drill the same size air valve hole on the opposite side of the wheel, install another valve and remove stems from both valves, With both valve stems at the 12 o'clock position, hook a small hose attached to the bottom of a large bucket of windshield wiper fluid, it will fill very quickly displacing the air out the extra valve stem, when fluid runs out of the other air valve replace the stems, This will add 80 lbs or more to each tire, won't freeze, won't rust out your rim, and won't kill grass/dog if a leak occurs, best of all its cheap.Tires are not loaded, but I do have 6 suitcase weights that go on the back when the blower is on. It does pretty good, but a little extra traction certainly wouldn't hurt anything.
I didn't really plan on getting the FEL anyway. About the only thing I'd use it for would be moving around firewood, like big rounds that I can't pick up by hand. I suppose it might be useful for moving snow, but I already have the blower for that. (and a plow on my 4 wheeler) Definitely not worth the $3K price tag. For that price or not much more, I could find a decent old tractor with a FEL or even an older skid loader.
i thought i would chime in. i run a 1948 farmall cub, i know its a farm tractor but its the smallest of the old farmall line. nice, reliable little C60 60 cubic inch flathead four cylinder that simple little engine will run for quite a few decades in between overhauls. that little four cylinder is a low RPM engine so its very fuel efficient, balanced, and has a long life as i said between rebuilds. that engine will burn less fuel then a smaller single or twin. im running a 60" danco C3 finish mower (the other option is the woods which by the way is still in production) and i push snow with a 54" blade. cubs are readily available and so are the parts (allot of reproduction stuff being made). its a useful little tractor, it wont break the bank and they are built like a larger tractor. i paid $1,800 for mine i have owned it 3 years and so far only replaced the front tires, the battery, and the normal paint and fluid changes. the tractor looks a little better then it did in this photo as i have since done a repaint on the front hood along with decals.
the cub is a serous little tractor built for light farming use, they arent out of place mowing, pushing snow, plowing 2-3 acres, or cultivating a larger lot. they are cultivating machines.
