I like the Hearthstone stoves looks quite a bit.
The guy I bought my Hitzer from had just bought a new $4000 (his words, not mine) Hearthstone to heat his 2200 sq. ft. home. This was I believe two years ago when we had that real bad cold snap here where we both live. He told me he loved the stove, got it sized to fit his house, but with the cold that winter being so cold he said it wouldn’t keep up with his not so well insulated home and that he had to fire up his grandma’s old wood cookstove just to help keep the place warm. All this while in his sons room sat the giant Hitzer 354 wood/coal stove that I ended up with. Was a no brained solution to me, but oh well...he thought he wanted a fancy stove. Nothing wrong with that and the problem was the weather and house that needed more insulation. It wasn’t the stoves fault. He was also trying to burn green wood in it as well, so that didn’t help things. He actually had 9 cords of wood he was trying to get seasoned that he’d stacked early that spring and had it covered. He was trying.
The point is...
That style of stove puts off soft heat they say, not the blaring radiant heat from a steel stove that he needed that particular winter. Also, the size of the home comes into play as does having a little stove left or a lot of stove left. A highly insulated home can stand a stove better that only has a littleextra heat left to radiate or to convert. An older, cut up design with little insulation will require a stove sized to have a lot of heating capability left in it.
In my mind the guy I bought my Hitzer from, he should have bought a Blaze King, King model and had the ability to turn the stove way down or run it on medium to medium-high when the house and weather conditions called for it. The Hearthstone stove he bought just couldn’t handle it by his own admission of having to run the kitchen cook stove...the Hearthstone dealer should have upsized his stove chive one model bigger for him. That was an expensive mistake!! $4000 virtually wasted.
Nit saying you need a King model for your house, but you know the size of stove you have now and what temps it takes to keep the home comfortable...or you soon will know this month. Use that information for helping to choose and size a new stove.
I am different than most on forums. I don’t feel you should have to run a stove cranked up all the time. In fact, with today’s stoves...like everything else built today...they are built to replace in a few short years rather than being built like tanks like older stoves. So in my mind get a stove to run mostly in the mid-range for your homes conditions. Use the temps you record from the stove you have, as well as your current stoves size, as a way to gauge your future stoves needs. Also keep in mind a radiant style stove or a convective type stove. Radiant will warm things in the house and will give a warmer feel...even a hot feeling in the house. Some use radiant and convective, like Lopi, Blaze King, Buck, and many others. Another thing to consider is a blower. My feeling is that it’s better to have it and not need it, than it is to need it and not have it. Blowers in stoves are like 4-wheel drive on trucks...the resale value is more and has more appeal.
Check out Regency stoves, Buck, and SBI brands like Drolet and Osborn as well as those mentioned above including Hearthstone and WoodStock. Kuma stoves are another great choice.
