I notice quite a bit of difference after one sharpening with the guide. It needs more but I'm on the right track!
Huh? I cut with saws wearing bars 14" thru 36". Any bar below 30" is a non-issue in the woods, so your comparison of 16" and 18" is just silly, in this regard. I use my 28" bar in the woods more per year than most folks here will do in five years, and it's never been an issue.- if you plan to cut in the woods at all,a longer bar gets in the way more
Rakers too high?So my saw now seems to spin and not be cutting now .... then it will bite in and cut like a dream. What is causing that?
If it starts cutting on an angle after it bites, your bar may be worn, or one side of chain wasn't sharpened correctly or at correct angle.So my saw now seems to spin and not be cutting now .... then it will bite in and cut like a dream. What is causing that?
I just actually cut wood with a chain saw for the first time. It's easy! I have some other things to do today but this log load is going to be rendered into rounds in the next few days I would imagine...then I will start splitting. I'm excited to get this done and learn some new skills. Thank you everyone for the input and help.
I can see it being a combination of the rakers and my poor chain sharpening skills I am working on improving.
But I'm also having a hard time understanding how one second it's cutting fine and the next it's just spinning in the log. That feels odd to me. If the rakers were to high it should never cut right? The poor sharpening makes more sense....maybe the saw needs to change it's alignment a little to bite in.
It's likely that one side of your chain is sharper than the other, as @Hogwildz mentioned.
Also, have you been turning your bar over every 2-3 times you sharpen your chain? This will help your bar wear more evenly.
What bar model do you have? Does it have a grease hole for the nose sprocket?
gerry I have not sawed a rock yet and only a tiny bit of dirt once. I am curious how the machine is junk but works???
Sportrider can you provide a link to the sharpener you are talking about?
Some tools are worth spending a great deal of money on, some are not.Here ya go. It's not amazing, but we are talking about removing depth (easy to set and repeatable) and angle (also easy to set and repeatable). It is a spinning disk under minimum load and it is much more repeatable than by hand for a beginner.....we aren't going to the moon here.Some tools are worth spending a great deal of money on, some are not.
http://www.harborfreight.com/electric-chain-saw-sharpener-61613.html
!I like the looks of that thing! Might just have to get one to help out. I probably will get another chain and use something like that to keep things "right" and then I can still use the hand sharpener at gas fills for touch ups. I really like working with a good chain letting it dull is a battle some people seem to like...not me LOL.
I got a snow day today! My school closed due to a power outage. I have done some work on the wood for certain. My log load is still here though LMAO!
