I have had my Sirocco 25 installed for two half seasons so far. I don't use wood as a primary heating source for my house, but I enjoying running it occasionally, sometimes for a few days at a time when the weather is colder (PNW mild climate, typically 30-45°F outside when I'm burning). I am using red oak that is seasoned for almost 3 years at this point. I also have some miscellaneous other firewood that I'm burning, including softwoods.
Likes
Likes
- I like the heat output and blower
- I like that I can turn it down to a fairly low level
- I like the clean look
- I like that there's no visible smoke outside once the cat is engaged
- I dislike how often I have to load it (every 2-4 hours)
- I dislike how smoky my house gets every time I load it
- I dislike how the insert becomes unstable and rocks (~1/2" of play, front/back pitch) when it heats up (maybe the bottom is bowing down as the metal expands?)
- Lack of insulation or block-off plate in my fireplace (chimney located in outside wall of house). I didn't hear about these until after my installer was done. He did use an insulated stove pipe as recommended.
- Wood too big: some pieces are long enough that they barely fit in the stove at an angle. I got the oak for free from a tree service and it was in massive pieces. I had to rent a hydraulic log splitter to cut it down but some of the pieces are close to 2' long.
- Will I have much better results if I spend hours cutting down all my firewood to 12-16" pieces and pack the firebox much more tightly? I think I know the answer.
- Will I be able to run the insert at low output even if it's jam packed?
- What else can I do to get better results?
![[Hearth.com] Likes/dislikes with my insert (Sirocco 25) [Hearth.com] Likes/dislikes with my insert (Sirocco 25)](https://www.hearth.com/talk/data/attachments/336/336398-99c16e959fd499217b44877c48321e1e.jpg?hash=0RwkGl6_n1)
![[Hearth.com] Likes/dislikes with my insert (Sirocco 25) [Hearth.com] Likes/dislikes with my insert (Sirocco 25)](https://www.hearth.com/talk/data/attachments/336/336443-e627c1a3fcf3cc3324541246737a3b2b.jpg?hash=sl_OR2UJAB)
![[Hearth.com] Likes/dislikes with my insert (Sirocco 25) [Hearth.com] Likes/dislikes with my insert (Sirocco 25)](https://www.hearth.com/talk/data/attachments/336/336444-4a306e7a58035b4efbf70f86b3d5be92.jpg?hash=-wLrWyYho7)
