Let's hear about your log splitter
From everything so far it sounds like the perfect solution.
I guess it's uncool to actually want to know what im dropping possibly a couple grand on. I guess I should just walk in and get another piece of crap splitter like the 35T Huskee I have. I took advice on the I&O. I called them. They were bought out. Impossible to walk in and buy one. I took advice and looked at the one at the DHT. Sorry that thing was a piece of crap too. I've mentioned several times that I was interested in 22T splitters. Not the 27T Troy Bilt which keeps being repeated. And is like 2 foot off the ground.
Reactions: Mike Fromme
Not only that, but if I'm going to be bending over that much with the Troy Bilt, I might as well split by hand. What joke.
See, now that you're not making snarky remarks, that's something I hadn't thought of. The larger rounds on a shorter splitter makes absolute sense. Since I can't stand splitting vertical. I most muscle up what I can.
For an awesome out of the box splitter, check out the Splitfire. Not cheap though.
I also prefer splitting horizontal, but wouldn't be without a splitter that can go vertical. I bring home a lot of BIG rounds (more than half over 40" diameter... once a 60" diameter oak), and there's just no way you're going to get a 40" round up onto a splitter.
[Hearth.com] Let's hear about your log splitter [Hearth.com] Let's hear about your log splitter
Yeah, it's just a Huskee 22 ton, but I've not run into anything I could move, that it couldn't split. I went with the 22-ton because it has a much faster cycle time than the 28-ton, due to using the same pump on both models.
A note on I&O, they do make two versions of most of their splitters. For example, in their 22 ton equivalent, you can buy a homeowner grade I&O with a 12 second cycle time, or a commercial grade unit with a 6-second cycle time. I used to rent one of the commercial I&O 22 ton machines locally, and it did stall in rounds my cheap 22-ton Huskee goes thru without trouble (albeit slowly...).
Reactions: whatsgnu
A LOT of wood has been split with the Huskee splitters of all sizes. I'm sure the same will be said about DHT tools after they've been out awhile longer. If you think their products are crap and can't find I&O, I think your best option is to custom build something. Clearly your standards are higher than the rest of us that get by fine with crappy big box store splitters.
Reactions: WiscWoody
By the time you hoisted that up there I'd be onto the next one.
Reactions: Ashful and osagebow
I'm in the market for a log splitter. A new one. 35 tons is simply just too much. So let's see/hear how much you love/hate your fluid power splitter. Which I'm sure this is also where the wise @$$3$ will pipe up and talk about their trusty 30lb maul.
I got an Ariens 27 Ton splitter last year, works vertical and horizontal, so far I am happy with it and it has split everything I have thrown at it. Got a 0% financing deal on it, 3 year warranty, so not a bad deal. Also bought an Ariens snowblower along with it.
  • [Hearth.com] Let's hear about your log splitter
Ariens 27 ton
Sorry that you been offended . The posts will be deleted and I will post no more .
I'm not offended. Just trying to figure out what's easier and/or faster about having to hoist and split over rolling the danged thing up to the splitter. Judging by your reaction, perhaps you are the offended one.
I ended up getting the 22 ton Ariens. I'm pretty pleased with it. No, I'm very pleased with it. It's easy to move by hand, easy to stand vertical, and it split everything I threw at it...including 40-46" rounds of oak. I really like the cycle time and the log cradle as well.
I should not, I really like your stacks. I can barely stack mine in a line with out them falling over at some point. I'm not even gin a try what you've got going on.
I got a huskey 22 ton. I had to rebuild the carb after sitting for 3 months this summer. Looks like i will be running stable ethanol treatment in every tank. But so far it seems to work really well and i have not ran into anything it won't split yet.
Reactions: scooby074
Chillax, man. Dano made a valid observation. We all have different ways of getting the job done, and each one has its pros and cons. You just have to decide what works for you.
Reactions: TreePointer
Agreed. I strive for quickest + easiest. If it'd only take me 2 more hours to hoist a round up and I'm not killing my back...I'm on board.
I bought a I&O brand new this past spring, I got the 20ton fast cycle with a Honda gx270, I have the option of splitting vertical or horizontal, I love doing both. My cycle time is about 8 seconds from start to full return, (very fast) 20ton seems like more than enough, I have gone through some very knotty oak's and maples and haven't had a piece I could not split yet. My local hardware store did a special order for me, I just had to ask. All in all I spent like $2,400 (including cradles)
My friend had the same unit that is about 6 years older than mine, there have been some changes, The new is not a full I-beam, the top plate is welded to the bottom, the bottom plate is noticeably thinner than the top, they did improve on the "log stops" by welding in a gusset for more support. It also seems that they improved how the ram / ibeam sits connected to the wheels. The log cradles are still as cheesey as the old ones, (I&O need to re-design them so the sit lower than the splitting plate, they are meant to cradle the log, no hold the log. At the end of the day I'm very happy with my splitter, If something should happen to mine I would order another identical one no questions asked. Also it might help for you to know I have split about 30 cords with this unit since the spring, if there was wear and tare it would start to show by now.
Wow, now that is some back yard wood processing, about 6 cords a month. Now that is a full time weekend job in sweltering heat, nice to hear it didn't overheat.
