Cold start, takes atleast 45 minutes to get to 1000 on the cat. I have to burn up the starting wood quite a bit before I close the damper at around 600 on the cat probe (30 minutes), then it takes it another 15 minutes to go over 1000.
Glad you found the thread and weighed in!I'm late to this thread but glad to see some other Buck 91 users here.
fire is started, if the fire is allowed to die down immediately it may go out or the combustor may stop working. Once the combustor starts working, heat generated in it by burning the smoke will keep it working." So it may be that the combustor is already burning the smoke, even starting from 400. However, I can go out, look at the stack, and still see smoke until the probe is over 1000, so...
If you fall asleep during the start-up fire, like I did this AM, cat probe will go over 1100.
When I get 800 or so on the probe, I load. I can tell the cat is burning if the probe temp doesn't drop much when I have the door open to load up, so I'll experiment with that and see if I can get it burning at a lower temp. As I've mentioned, I've had the probe approach 1800 a couple of time, which I want to avoid. I think that has happened because, in trying to get from 600 to 1000, I've gotten too much of the load burning. Also, the air coming in from the ash drop lid really makes the left side of the load take off once it gets burning. To keep most of the load from getting involved early, when I load I'll push the coals to the middle N/S. Then I grab two big split and, using the fat sides as 'walls,' push the coals into as thin a N/S line as I can. I then build up the far left and right sides with big splits. Lastly, I put a few smaller splits in the center on top of the coals. I then clear out any coals/ash in front of the 'shot gun air box.' To get some flame going and the cat chewing, I use mainly shot gun (doghouse) air (left slider,) with little or no air coming into the air wash and the other channel half way back in the top of the fire box (right slider.) I figure this sends hotter air to the cat. It also keeps the load burning in the very center instead of getting more wood involved like the air wash does. I cut the shot gun air and cruise it with the air wash closed, or slightly open. I think this method may allow me to cruise with the air open a little more when I need more heat, with the load burning in a more even, controlled manner. It might put out more heat later in the load. Up 'til now I've been having my MIL open up the air a bit in the afternoon to get more heat and burn the coals down for the reload.
Yep, pretty nice to have a half-cord or so stacked up next to the stove.WoodpileOCD: I am jealous you are able to have wood inside this year, this is the first year I have had to keep the wood outside on the porch and bring in a load at a time, we have been having huge issues with spiders this year coming in on the wood (kids and wife are not to keen on them).
It is pretty cool how the Appalachian stoves are pretty close to the Bucks in terms of operation, probably can say the same for the Stoll 1500,2500 stoves.
Those Appalachians look almost identical...
Wow, that looks great. The elevated hearth accents the free-standing look. And you don't have to crawl around on your knees!Here is a picture of my stove. I chose to not use the surround as I thought I would get more heat out of it. I painted the inside of the fireplace black and I like the look of it. Kind of a freestanding stove in the fireplace rather than the classic insert look.
What's that leaning up in the corner, a bong? Gives a whole new meaning to the phrase "That cat is lit off."
