We bought a foreclosure two years ago, which came with a CL4030 boiler. The house has a package heat pump with a HX bolted to the exhaust duct between the heat pump and the house. It's our second home, primarily use it on weekends, so its not permanently occupied. During the winter we usually set the heat pump to 45 degrees and don't run the OWB unless we're out there. Last winter, the heat pump malfunctioned during a two day cold spell, we didn't know it and the heat exchanger froze and took out 6 tubes. $160 for a new HX.
Don't want to really use antifreeze so my idea is to split the hot wire going to the circulator into two parallel legs. One with a thermostat, the other with an on/off switch. If we fire the boiler, the switch is on and the circulator runs. If it's off, then if the temperature drops below say 40F, the circulator kicks on and runs keeping the HX from freezing. This would only be for those days where it's like 50 in the day and 25 at night. Thoughts?
