Hello Everyone,
I hope the summer is going well.
After continued extensive research I finally put a deposit down on an HI300 black matte finish like Velvetfoot's unit above. It is a floor model from a dealer that is out of state, but after negotiations the price for the unit and a 6'X25' liner was too good to pass up. I hope to take the road trip to pick it up in the near future.
I'm hoping to get some final feedback prior to picking it up.
Question #1.
The HI300 with a standard cast face plate has the following dimensions:
Minimum Fireplace Opening
Width (front)23.75" My masonry firebox - OK - 36.5"
Width (back)23.25" My masonry firebox - NOT OK - 21.5" - see notes below
Height21.5" My masonry firebox - OK - 28"
Depth17.5" My masonry firebox - OK - 19"
The one measurement that appears to be an issue is the width in the back. The unit has 2 small leveling feet attached to the back firebox. These are included in the final back width of 23.25". The back width of my firebox is 21.5" After discussion with a reputable local dealer I was advised that I could cut off those two leveling feet and the unit width would be exactly 21.5". We measured it at the store and that is the correct length It's the only way to have the unit fit w/o altering the masonry firebox. It would be tight, but it should fit.
I'm wondering if cutting off the rear leveling feet would void any warranty from Regency?
From the manual:
"The warranty will not extend to any part which has been tampered with or altered in any way, or in our judgment has been subject to misuse, improper installation, negligence or accident, spillage or downdrafts caused by environmental or geographical conditions, inadequate ventilation, excessive offsets, negative air pressure caused by mechanical systems such as furnaces, fans, clothes dryer, etc."
HI300 Manual
http://manuals.regency-fire.com/get...7-9b24-7f875e9c1f05/HI300-English-Manual.aspx
Question #2:
One really annoying thing is my masonry firebox sits 1" higher then the tile hearth. The hearth is currently 18.5" from the face of the firebox. With this unit I will need hearth extension regardless.
A few options are being considered:
1. Custom hearth pad. This would work, but due to the wood trim work notches etc it could end up being costly. I'm thinking one granite piece, but I still have yet to price out the job.
2. Standard hearth pad- This is probably the easiest solution, but appearance wise may not be the best looking
3. Redo the hearth completely - This is extremely costly - I was quoted $1800-2000 to do so. Not really an option with the current budget.
4. The last option I am considering is using some cement board to build a template that will cover just the length of the cast iron face plate and the front section with some metal trim to match the matte black of the unit. Or I'd have some black metal pieces fabricated/welded as a basic frame to support the unit and frame then using basic standard thin hearth extension.
Any input is appreciated.
Thanks
