SeñorFuego
Hi Folks,
Newbie here. I'm lovin' the forum and find it very informative.
I'm looking into different options for a fireplace install (freestanding inside the firebox or insert). The Neo 1.6 Insert is a possible insert option and is carried by a local retailer. I've read decent reviews on the PE products and I like the large window and clean lines this model offers.
I'm checking to see if folks using the Neo 1.6 are still pleased with it's function and output. We are in a classic NE Cape style home (1400 SF) and the fireplace is located in the main living/TV room. We'd most likely have the blower off during TV time and on at other times for maximum heating efficiency. This would be used as supplemental heat to take the chill off, but also with a goal to reduce heating oil consumption also.
I'm curious on the following:
How's the blower noise?
With the blower off what is the convection output? Is it solid? Could it hold us over during a power outage? It appears that the PE units have a special design to assist with this (I know without the blower there is only some much it can do).
What burn times are folks seeing?
Would you recommend this model?
If the Neo 1.6 wins out I'd probably attempt a similar install as SwordWord did as we have almost an identical mantel and hearth set up.
Any input is much appreciated!
