Bioburner
Moderator
Going to have to get some more revenue to pay for health care somewhere.Th e $8 for gasoline in Europe is mostly taxes.
Yet it still costs more here.Going to have to get some more revenue to pay for health care somewhere.
Couple of points. As much as I like pellets, I need a new central heating system. I plan to be in my house for awhile but I need a central heating system in the event I sell my property. No one is going to buy a house heated with just a p35i where dad has to shovel pellets into a boiler in the basement. I'm not going to put in a geothermal system and I'm not going to get a pellet boiler. Ain't going to happen -- but all the power to those doing it. So my options are: get a better oil boiler or go with gas. I chose gas because I'd like to get a gas stove in my kitchen someday, NG is currently MUCH cheaper than oil, I don't like oil, and the new mod/con gas systems are very, very efficient. For me, it's a no brainer. As for Massachusetts, the MassSave program (funded by assessments on our utility bills, not tax dollars) is providing, in conjunction with National Grid, $2300 in rebates on the equipment and 0% financing for seven years. I don't want to veer off into the Ash Can, but I love living in the Commonwealth. I'm not asking for a "free ride" just a good quality of life -- and I'm living it. Stay warm everybody. Now, I'm going to go listen to Maria Muldaur's "Midnight at the Oasis" (1973) to keep the oil-burning vibe going.
Yes, we had to cycle on/off every 15 minutes if you wanted that rate but only in high peak times. It was a non issue for me as I always kept the house cool. It would be a problem if you came home from work and tried to cool down your house when they were cycling it. They also let you hook up your furnace to get that rate to run it year around. And if you were good with electric like me maybe even your washer and dryer since it was by the of peak box, just..... Maybe...My electric company is having a seminar on new heating and cooling technology next month. Will have to check out as we need to install conventional system if we wish to sell house. They charge 6 cents also but have a summer surcharge with a small incentive to cycle in summer.
The bigger issue to me is the fact that I am forced by the government to fund improvements to other peoples property. Save your money and pay for your own improvements.All utility consumers in Massachusetts pay "an assessment" on their bills. On my NStar electric bill it's the "Energy Conservation" line item. On your gas bill it's probably labeled something else. Through that funding, the utility companies sponsor MassSave. I don't have gas now so the money collected through my utility bill since 2008 has helped fund the dense-packed insulation in my walls and my oil-to-gas 0% interest loan. So, yes, Electric assessments do in part fund gas incentives. Flammam, you already wrote in another post that you didn't approve of MassSave because you didn't want "the government" on your land. Sorry you can't get a loan to do conservation work. Sorry you don't like your lightbulbs.
I am, as I said, only interested in installing a system that will get the permits ok and provide a central air system.
but gas is usually much cheaper
Yep. Same thing happens with gasoline. That's why when politicians cheer drill baby drill to a screaming crowd I wish I could say "you know nothing guarantees this oil stays here right?" Same principal. When Europe pays 8 bucks a gallon for gas, you tell me where the newly drilled oil will go...
I'll probably never even get cable/broadband, never mind natural gas.there are an awful lot of areas that will NEVER see NG at the street.
I ended up with cable etc because they were replacing the copper phone lines and is cheaper to run fiber optic.I'll probably never even get cable/broadband, never mind natural gas.
Even the heat pump with a ground coil can't compete with what it will cost to heat with biomass (shells)
The current house here can be heated for approx. $100 a season.
The heat pumps, unless they have a ground coil will be basically worthless below about 40 F and we are not adding the heater strips, that's just a waste of $$$$$
We have never used the Electric heat here in the house in the 21 years we have been here.
Tooooooooooooooooooooo spendy to run electric heat.
Our electric runs $300 mo anyway
Central AC is a must.
After doing some calcs, for sure we can heat that new shack for under $200 for winter season (Oct to May) That's $25 a month, and I am figuring COLD weather.
I was generous with the figures, so likely the cost will be less.
Biomass fuels are certainly not as easy as just twisting the stat and then paying the bill every month, but far easier on the check book.
We know some folks that have a home built at the same time ours was built and the same floor plan, the guys wife is deathly scared of anything that burns anything, so they heat with electric.
Cost them $1200 mo to heat the shack. OMG, THATS 12 YEARS FOR US![]()
I know I'll never see NG here. I can't even get any broadcast channels with a 70' tower and a huge Channel Master antenna and amplifier let alone cable. But good thing they did run fiber not far from here so I get 10Mb DSL which is enough speed to get me good Netflix and prime.I'll probably never even get cable/broadband, never mind natural gas.
I had a customer with a 45 call me and he had been complaining he wasn't getting enough heat and had been fighting with it all winter. Finally took the pot out of the stove and cleaned out all the holes with a 1/8 drill bit. Guess it is working like new now. I guess I had assumed he had been cleaning it as the book says but nope he hadn't cleaned it.That isn't your radiators pinging, it's all the money going to oil companies, just like slot machines in a casino, the house always wins![]()
We at least get 3g. Hoping that 4g makes it here at some point. Problem is they charge you for using that bandwidth.I know I'll never see NG here. I can't even get any broadcast channels with a 70' tower and a huge Channel Master antenna and amplifier let alone cable. But good thing they did run fiber not far from here so I get 10Mb DSL which is enough speed to get me good Netflix and prime.
You can't get any DSL even? I can use up to 250Gb a month and I use a lot! I also have a table top int radio that's on all the time for my talk radio (non political!) fix. And I use a Nettalk VoIP telephony. If I ever move that's one thing I have to have is good broadband.We at least get 3g. Hoping that 4g makes it here at some point. Problem is they charge you for using that bandwidth.
