It does not really effect me though right? The hearth should take care of all that. My worst nightmare is getting one of these stoves and having major issues with it. It is my primary and really going to be my sole heat source so I cannot afford a major issue.Take note of rear clearances of any stove you consider. A heat shield behind the stove and stove pipe can reduce clearances even further, but in some instances, for whatever reasons, people may not want to install a heat shield behind the stove.
I only mention that because the Woodstock stoves may need slightly more clearance if I recall correctly. Just be aware this is something you may want to pay attention to.I don’t for see anything with that install, nut you never know.
So just pointing out that Blaze King and even others have totally contradicted this. Blaze King told me that 16" splits are recommended in the stove and that you could squeeze 18" splits in it but it was not recommended. So 22" seems like a bit much from what I have been hearing?Not sure if it was already mentioned. Did not read the whole post. The Princess will take 22” splits e/w.
16-18" is recommended, because you can load them north-south, which allows better and fuller loading without logs rolling out.So just pointing out that Blaze King and even others have totally contradicted this. Blaze King told me that 16" splits are recommended in the stove and that you could squeeze 18" splits in it but it was not recommended. So 22" seems like a bit much from what I have been hearing?
Do you have any idea what is behind the hearth? Clearance to combustibles? Air gap behind the bricks?It does not really effect me though right? The hearth should take care of all that. My worst nightmare is getting one of these stoves and having major issues with it. It is my primary and really going to be my sole heat source so I cannot afford a major issue.
👍16-18" is recommended, because you can load them north-south, which allows better and fuller loading without logs rolling out.
But if you have some wood that is already cut to 22", then I suppose Diabel is pointing out that you can burn by loading east-west. Not preferred, due to logs trying to roll out or up against the door, but do-able.
Well the hearth is mostly underground and the brick work is still in pretty great shape considering how old it is. The wall side is in especially good shape. The chimney side goes out into a flower bed, so nothing to worry about there. So I think this house was built in 1985 and the chimney was added at that time. So it is coming up on being forty years old.Do you have any idea what is behind the hearth? Clearance to combustibles? Air gap behind the bricks?
Yeah like I said this one has been like this from 1985 so I consider myself lucky. I just had a guy look at it and he said minor work but it definitely needed to be addressed.Yeah, the core bricks should go. Not sure what someone was thinking, using them like that, but if the bedding mortar below them is solid, at least that's keeping water from going further than that core itself.
Crowns are not forever, they need to be touched up and replaced more than any other part of the chimney. Even if there are no obvious stability issues, try to get them checked at least once every 10 years.
Worth discussing. This is really simple physics, and no stove or manufacturer can break physics.He said that other stoves like Regency do not have the requirements that the Blaze King stoves do.
Thanks I just sent some information out to several people so far. She definitely said 36" over the phone and probably cause well, that is what is recommended lol. My cheapest and perhaps best option is to try to do this myself with someone helping me and maybe even getting my own stove. For instance, I could probably save a lot of money by getting and insulating the liner myself and buying an Ideal Steel from Woodstock. That way I would also be putting in whatever liner I decided to purchase.
An oval liner will do it. Duraliner oval is pre-insulated and comes in at 4 3/4" x 7 3/4".It’s going to be tough to reline that chimney with a 6.75” width. Your probably going to have to bust out the tiles especially if you insulate the liner which is highly recommended. Maybe you could fit an ovalized liner down there?
Okay so I know you did not put 'absolutes' on anything but having my situation in mind do you (and others) think I should avoid a catalytic stove all together or just the Blaze King's because of their requirements?Worth discussing. This is really simple physics, and no stove or manufacturer can break physics.
Blaze King has made a market for themselves by really pushing the envelope on super long burn times. And if you want to play in that club, bragging here next year about your 30+ hour burn times, you do need a pretty good setup to support that. The ability to properly draft the stove with a good chimney has direct bearing on the "stall point", essentially how low you can run the thing before it stalls and dies.
At the other extreme, you could install and run a Blaze King on the same marginal chimney as most others. There is absolutely no technical problem with that, but you're cutting its legs out from under it, removing its ability to do the one thing that made you buy (and maybe pay more for) this brand. As others have already said in other threads, don't bother buying a Blaze King, if you intend to only ever run it like a non-cat. It's just a waste.
Somewhere between these two extremes is where the rest of us in the real world land. We might not have an "ideal" chimney, but we have something good enough to allow us to push the thing lower than we might reach with other brands, and we call that compromise.
This. I talked to Eric from rockfordchimneysupply.com and he said 5" x 8.15" would put me around 6" x 9.15" with the liner insulated. He also mentioned 4.5" x 9.1" but he said before he said anymore he wanted to know some other specifics. I plan to talk to him today or tomorrow hopefully.An oval liner will do it. Duraliner oval is pre-insulated and comes in at 4 3/4" x 7 3/4".
I don't think they sell DuraLiner which is a rigid liner system.This. I talked to Eric from rockfordchimneysupply.com and he said 5" x 8.15" would put me around 6" x 9.15" with the liner insulated. He also mentioned 4.5" x 9.1" but he said before he said anymore he wanted to know some other specifics. I plan to talk to him today or tomorrow hopefully.
I think you can't go wrong with the Blaze King in this case, because:Okay so I know you did not put 'absolutes' on anything but having my situation in mind do you (and others) think I should avoid a catalytic stove all together or just the Blaze King's because of their requirements?
I do appreciate all the feedback and honesty I have found here. I am just trying to make the right decision the first time, because as I said before there is no room for error with this being my primary heat source.
He got my information and I just spoke to him. He recommended going with a rectangle liner. This is the one he sent. He said it is .006 thick which referring to the information @bholler posted is pretty light duty/corrugated material. Also confirms your post as well. Regardless Eric from rockfordchimneysupply.com has been very professional. This setup all together, even with the installation and stove pipe would run me approximately $2,000.I don't think they sell DuraLiner which is a rigid liner system.
Why did they recommend rectangle? That is oddHe got my information and I just spoke to him. He recommended going with a rectangle liner. This is the one he sent. He said it is .006 thick which referring to the information @bholler posted is pretty light duty/corrugated material. Also confirms your post as well. Regardless Eric from rockfordchimneysupply.com has been very professional. This setup all together, even with the installation and stove pipe would run me approximately $2,000.
Rectangle Chimney Liner Kits - Rectangle Flex Stainless Steel Liner Kits - Rockford Chimney
Shop rectangular chimney liner kits. Rectangle chimney flue pipe kits made with flexible 316Ti stainless steel. Shaped chimney liner calculator & DIY guide.www.rockfordchimneysupply.com
Agreed. How would that be better than 6" round? When insulated, it's going to bind.Why did they recommend rectangle? That is odd
A 6" equivalent rectangle is only about 4.5 x 9 or so. So it would fit. But rectangle costs more than oval doesn't draft as well and isn't as flexible. Just doesn't make sense to me.How would that be better than 6" round? When insulated, it's going to bind.
