We recently purchased a Jotul Rockland 550 insert to replace a VC Intrepid 2 stove that we used for 25 years. We have a 6" SS flex liner in our 18' chimney. We never had any issues with the VC stove. With the Jotul insert it seems that it is almost impossible to reload the fire without getting some smoke or fumes in the house. It drafts great when it is fired up to temperature. When reloading, I have a window open as our house is a bit tight. I crack the door for a minute to let the draft pick up and then I open the door slowly. When putting wood in it seems that inevitably some fumes/smoke spill out of the insert. I believe that this is due to the design of the Rockland. It has a large front door, a wide but shallow chamber and a small flue opening that is less in width than the front door. It seems to me that no amount of draft can suck out the volume of fire that this unit produces. My daughter has a Hampton 300 in a similar ranch house like ours. Our friends have an Enviro Boston. They do not have problems like I do. Their units are narrower and deeper, with a large flue opening across the entire front of the door. I believe that these units contain the fire better when the door is opened and prevent the spillage of fumes. It seems that the Jotul design, when it is burning up to temperature with good secondary combustion, throws a lot of flame and heat at the front door. With the Jotul it seems like you have to be almost perfect when you reload. If you let the fire die down too much, you loose draft and when you reload smoke/fumes spill out. If you reload too early when the fire is going to strong, there is just too much heat and fumes projecting forward for it all to get sucked up the flue. The door opening is so big that all of the air rushing in creates a lot of fire that can't possibly go up a 6" pipe. Does anyone else have a similar experience with the Jotul or helpful advice? We love the looks of the unit, it burns great, the heat output is adequate for us, but we are frustrated by the reloading issue with smoke.
