Yes. But there were no beeps when i put the paper clip into the hole on the battery pack.
Hey Flambo, try this I found on the online manual for this unit on page 24
Initializing the System
1. Press the Controls Access Door to release the magnetic
catch and swing the panel down.
Switch the Burner to OFF.
2. Install three AAA batteries into the Transmitter.
3. Press the black (or red) button on the left front corner
of the IFC board, next to the controls switch plate.
The board will “beep” three times and a yellow LED
indicates a 10-second synchronization time limit.
4. Within the 10-second time frame, push the ON button
on the Transmitter. The IFC will “beep” four times to
indicate that it has acknowledged the transmitter
command and sets to the particular code of that
Transmitter.
5. After initialization, the burner switch must be placed
in the ON position and Pilot Mode switch placed in CPI.
The remote can then be used to control the burner.
P.S. you can find a link to the manual here - (broken link removed to http://jotul.com/ca/products/gas-stoves/_attachment/50109?_download=true&_ts=15b1f6b2c36)
I hope this helps,
Cheers,
Taargon
