What is the remedy to keep this stove from over firing?Is it about the gaskets?They all seem pretty good,would the gaskets be the cause?Thanks
Thank you,will do that this eve,have a great day. .BrianCheck around your stove with a smoke stick or an incense stick or a cigarette, while it's got a good fire going.
If smoke gets drawn into the stove in an area other than the primary air intake, there's your trouble spot.
It was glowing red hot at the back of the fire box lower ends,could not reduce intake, with it dampered, to slow it enough..nervous hour or two,.It was cold ,and as our only source of heat,I loaded it late at nite! Thank you for your assistance, and will check these things ,prior to going to play tugboat!Yeah, nothing unique about this stove, other than it being a typical cast iron stove with cemented joints all 'round. All three doors (ash pan, front, lid) have a high probability of being the problem, as all three have their own flaws:
1. Ash pan door, wide but not tall, puts a ton of stress on that hinge. Make sure hinge is solid, and that door is landing on gasket when closed.
2. Front doors, the double door is tricky, particularly the gasket between them. It should be 1/4" braided (not woven) gasket around the perimeter of both, and 3/16" braided (online manual has a typo, here) between the doors. There is always likelihood of leakage at the top corner of either door, or the top edge between the doors, since the latch is at the bottom.
3. Ash door, this gasket must be 1/4" braided (not woven), and perfectly installed, since you're only relying on gravity and the weight of the door for a good seal.
So, I'd remove all of the inner panels (both sides and rear), and do the bright light trick first. Try the smoke / incense from outside, and dollar bill on ash and front doors, as well. If that fails, start pulling and replacing gaskets, starting with ash door.
BTW... what do you classify as "over fire"? How long have you been running this stove, and has performance recently changed?
Running it 3 years,and it seems to be burning clean ,mornings ,the top door is light ash color..seems pretty good.Yeah, nothing unique about this stove, other than it being a typical cast iron stove with cemented joints all 'round. All three doors (ash pan, front, lid) have a high probability of being the problem, as all three have their own flaws:
Actually, I've taken apart 20+ year old Firelights, and that gasket is usually perfect unless someone before monkeyed with taking the top off. With the stove assembled, there's really nothing that can happen to it. It's a very cool design feature.Hey don't overlook the fa ct that the top of that stove is not cemented on, but bolted down with a GASKET!! Crazy but true. It would totally be worth unbolting the top and checking that gasket. Bet it's pretty ratty by now...
Thank you,i'm in the process of taking this stove apart.Hey don't overlook the fa ct that the top of that stove is not cemented on, but bolted down with a GASKET!! Crazy but true. It would totally be worth unbolting the top and checking that gasket. Bet it's pretty ratty by now...
Hi ashful, are there only two side bolts on the top?I plan on all gaskets,do you have a suggestion on the extent to go..thanksActually, I've taken apart 20+ year old Firelights, and that gasket is usually perfect unless someone before monkeyed with taking the top off. With the stove assembled, there's really nothing that can happen to it. It's a very cool design feature.
There are gaskets that could leak, but my money is on the three sets of door gaskets, not this one. I've seen more than one Firelight with the top load door gasket glued in wrong. It should be glued to the stove (with minimal cement), and not to the top-load door.
I read a post from ashful saying to get to the inner back plate you need to pull the top out, being careful not to damage the bypass plates, then the back plate will lift right out, look it upafternoon Ashful,am doing the cat chamber and a new cat,also the gaskets,am having a time of removing the inner back plate.I removed the top and gasket is goog one bolt wes loose,which might of had a lio to do with my inital over heating last year,putting some money into this .Saw your comment about just buying a new stove,the scott in me if doing battle on that front.I know you are not too keen on a cat in these,but im stubborn,and will try one any way,are the steel ones any good,found both ,ceramic and steel,thank you for your 2 cents,Brian
I have found some ceramic ones with no bands but just slightly under sized ,would they work?My memory on cat's in the Jotul 12:
1. Original Corning OEM cat seemed to hold up okay. Never had any issue with them, other than being old and depleted.
2. Condar SteelCats (diesel foil, ca.2013) did not survive. They got hot enough to distort, which caused the small passages to close off. They actually burned thru the side walls at the welds that hold them together, as well. Condar reported many others were having the same problem in their downdraft cat stoves (Jotul 12's and VC's).
3. Condar ceramic cats worked well, except the expanding gasket they install between the ceramic element and steel can would expand a little, and this damaged my refractory cat chamber and cover. That set of refractory parts cost $515 + s/h, as of last purchase, so this was not acceptable.
4. Firecat combustor was the one that really took off in both my stoves, going over 2000 F in each. The metal can completely melted off both. I blamed the cat, at the time, but do wonder now if there was some other damage causing the cat to go nuclear. The odd thing is that one was run in a stove that had just previously run a Condar cat, and the other was in a freshly-rebuilt stove (new refractory). Both stoves were subsequently run on old OEM cat's again, with no issues.
So, the big question then is... what the hell can you use? You can't buy the original OEM Corning cat assembly.
Some have purchased Condar ceramic cat's, and simply replaced the expanding gasket material with something else. Some used gasket cement for this, which I suspect will result in a fractured ceramic (CTE mismatch). I never did this myself, but I'd be packing the gap with regular fiberglass gasket rope, if I were to go this route.
My solution was to go on ebay and buy up every old OEM Corning catalytic combustor I could find. I ended up finding three good ones, over the course of a few months, and I was set. They were old, and maybe somewhat depleted, but they worked.
Lid has been off whole time have to loosen or remove the damper frame.You may find this helpful:
https://www.hearth.com/talk/threads/yikes-1035f-on-outside-of-stove.140222/page-4#post-1897367
Fire back is loose ,seems to be of angle,hits on the damper /footpeddle channel at an angle ,won't come clear to remove, damper frame Har to take our and reinstall?Was your damper frame installed over inner fire back? Should be under it, from my memory, not over it. I never had to remove damper frame to pull inner fireback, as you can see in those photos.
