Hey Everyone,
I have a Jotul F500 manufactured in 2000 (V1 I guess) that I bought used a few years back. I've burned in it the past 2 winters but haven't really been impressed with the performance - ie burns faster than expected, burns vigorously when the air inlet is closed completely as if there's another source of air(seemingly from below), lackluster heat output at operating temps. The stove is in my basement on an exterior wall installed in a typical masonry chimney. Chimney is roughly 26' tall. I had an f400 in the same spot 3 years ago and it performed beautifully, but I decided to upgrade to the f500 for more heat. My baseline reference is the 2010 F500 my brother has in a near identical set up.
I reached the point where I was going to perform a complete rebuild so I could re-cement the seams of the stove, but before doing that I wanted to be sure there wasn't something else I overlooked. Sure enough, when I put a flashlight in the ashpan housing and close the door, there are two pretty big gaps at the top corners of the ash pan door(see pics). The original owners manual calls for 1/4" LD gasket, which is what I used when I replaced it 2 years ago, and the door closes tight and passes that dollar bill test.
Has anyone else experienced this and if so what was the fix?
Thanks in advance!
![[Hearth.com] Jotul F500 Ashpan Door Gasket Gaps [Hearth.com] Jotul F500 Ashpan Door Gasket Gaps](https://www.hearth.com/talk/data/attachments/315/315930-d8e6ff025d9b3b10039c7d906932ae7b.jpg?hash=t4RxnIzafp)
Thanks in advance!
![[Hearth.com] Jotul F500 Ashpan Door Gasket Gaps [Hearth.com] Jotul F500 Ashpan Door Gasket Gaps](https://www.hearth.com/talk/data/attachments/315/315929-b759c91d329b41804d7a18fcb3c2655e.jpg?hash=2-Zol31oFD)
