NH_Wood said:oldspark said:Oak is not worth a crap for starting fires, is your maple soft or hard, you need a less dense wood for starting fires and Oak is not it, Oak needs a good bed of coals to catch fire. Are you checking the splits for moisture on a fresh split and not on the outside?
Oldspark is dead on here - oak or other very dense wood is a bear to use when starting fresh fires - using less dense woods, red maple, white birch, cherry, etc., are great for adding to an early fire at this time of year (keep them split on the smaller side). Cheers!
Sounds good, if you actually HAVE red maple, white birch, cherry, etc. However... I only have oak and a wee bit of hickory. I not only make due with it... I do very well with it. That's pretty much all I burn and have no problem with getting a fire started with it.
And I don't use lighter fluid!
