I"m with ya on that!I hate splitting vertical. Log lifter is the cat's @$$.
I may be new to burning wood for heat but not to physical labor. And even though I never used a vertical splitter IMO and only IMO THEY look like back breakers. I watched a few you tube videos of guys that were practically crawling on the ground. IF I were to get a vertical splitter, I already thought how I would build a large base to fit around the little base on the splitter so really big rounds can sit completely even and not want to fall off.
But being that i have allready been pampered by using a relatively new TW-5 with a log lifter and out feed table I'm finding it hard to get anything else. I had some rounds close to 30" in diameter by 24" long and the hydraulic log lifter picks it up with ease and the I-Beam has two wings that cradle it and then when it splits the out feed table holds the two halves. Man it is so easy. Even easier when I used the 4 way or 6 way wedge.
I will say that I wish the whole splitter sat a few inches higher because I still had to bend a little but I already have engineered ( in my mind) how to raise the unit and build a little ramp up to the log lifter to make up for the height difference.
Ok back to what this thing might be worth. (other than a pile of scrap metal)
hence why I started burning wood and not buying oil.
