It is a Timberwolf TW-5.
I don't know how old it is nor does the owner. The tag with all the info is ripped off the frame.
The guy selling it is a tree service company I have known for 15 years.
They do a lot of work and pump out a lot of firewood.
They have several other processing machines and they just bought another monster.
This was never really used as a main source but The machine definitely has seen thousands of cords.
They claim to really maintain their equipment which I can see just by looking around their yard.
It has electric start but there was no battery hooked up and it started with 2 pulls.
The only major thing wrong is the push block. They have welded the brackets that ride on the I-beam several times and it obviously is broken again.
The I-beam itself is perfectly flat on the top but it is worn unevenly underneath where the brackets ride.
It looks there shoulkd be a cover plate where the engine shaft is connected to the pump.
The muffler is missing the the heat shroud and is pretty loud for a Honda and exhaust leaks from the screw holes where the shroud attaches.
The push rod cylinder shows no signs of leaking and slides in and out smoothly.
I didn't try to split anything with the way the push block is for fear of doing damage.
There is some grease/oil build up around the controls and the base but not much.
I used a TW5 that a different friend has and it is a beast. That one actually had more grease/oil build up then this one and would drip on my driveway.
I spoke to a Timberwolf dealer and he said the push block is $600 and the I-beam is $1500 but as long as the block is welded securely and the I-beam is flat there would be no need to replace them.
I guess I should have him weld the block on and then let me test it for a day to see how it handles under load.
![Is this splitter worth $1500 Is this splitter worth $1500](/talk/proxy.php?image=http%3A%2F%2Fimg338.imageshack.us%2Fimg338%2F1556%2Fimagengep.jpg&hash=243b8cbec50167085dd9a3313ac9f1c9)
![Is this splitter worth $1500 Is this splitter worth $1500](/talk/proxy.php?image=http%3A%2F%2Fimg594.imageshack.us%2Fimg594%2F407%2Fimageoyno.jpg&hash=1a7354ff8843ccd0b41fed43b8fd57b2)
![Is this splitter worth $1500 Is this splitter worth $1500](/talk/proxy.php?image=http%3A%2F%2Fimg822.imageshack.us%2Fimg822%2F985%2Fimageegqs.jpg&hash=b7b88450c23c8ca087e75af61db5937d)
![Is this splitter worth $1500 Is this splitter worth $1500](/talk/proxy.php?image=http%3A%2F%2Fimg269.imageshack.us%2Fimg269%2F8181%2Fphototp.jpg&hash=72938b8976e7f6629ac6efc822c94130)
![Is this splitter worth $1500 Is this splitter worth $1500](/talk/proxy.php?image=http%3A%2F%2Fimg855.imageshack.us%2Fimg855%2F7677%2Fimagevrso.jpg&hash=751c70c7b38e0f9def3b8590466197e9)
![Is this splitter worth $1500 Is this splitter worth $1500](/talk/proxy.php?image=http%3A%2F%2Fimg52.imageshack.us%2Fimg52%2F4718%2Fphototqz.jpg&hash=9da755a3a329e6f0f5df755a614eecc9)
![Is this splitter worth $1500 Is this splitter worth $1500](/talk/proxy.php?image=http%3A%2F%2Fimg191.imageshack.us%2Fimg191%2F6987%2Fimagelpvh.jpg&hash=15627f87eef1a828c866d56d6b380e5a)
