Hello, I am in the process of deciding on what wood stove to purchase in my 70's split level 1400 sq/ft home (average winter temps -20C). I need a stove that will serve as the primary heat source and will be capable of 8+ hour burns (while overnight and at work). It will be replacing an aging corn stove in the finished lower level rec room that has an air exchanger right near it delivering warm air to the upper levels through duct work. There are also french doors leading the upstairs.
From what I can see from reading this forum, a larger stove that can handle more wood is the way to go for long burns. With that in mind, I have been looking at the Drolet HT2000. 3.7 cu/ft. I'm just worried that a larger stove with big BTU/hr might melt my face when in the room. Should I be looking at smaller stoves? could I just build smaller fires or close dampers if things get too hot down there? Thanks!
