hello all--
as I ponder and plan for effective storage that'll fit through my basement access hatch and also not be crushingly expensive, here's a question that crossed my mind--
I'm familiar with the distinctions between pressurized and un-pressurized, both in terms of pressurized's ability to skip the intervening heat exchangers, and also the need to not have the system open to the atmosphere, so as to keep the oxygen levels low to avoid rusting the boiler
my question is this- how much pressure does a pressurized system need to actually run and maintain in order to have that closed direct loop from steel boiler jacket to steel storage tank, and also avoid corrosion
Would it be close enough to pressurized if I had my boiler and main storage in the cellar, with a modest sized auxiliary expansion tank, open to atmosphere at its top, on the first floor-- by having the top of that tank open, it would never build up any significant pressure, but also (as long as it's monitored) would never allow air down into tha "main loop" of the boiler-tank-boiler path?
such an arrangement might allow me to use certain types of storage tanks that, while not rated for pressure in the sense of any significant PSI level, could probably hold just fine with the mere gravity pressure from that upper tank.
I'm just not clear on whether there's a certain PSI threshold that one has to hit in a pressurized system in order to get the oxygen out and keep it out
as always, thoughts and suggestions much appreciated!
Trevor
Trevor
