Woody,
I said the PH was much more controllable than the Fireview, which itself is very safe and controllable. I believe both present very low risk for true runaway fire.
I'm assuming all cases of overfiring of a well designed stove are caused by operator error.
And certainly in my case operator error has occurred because of distractions when loading the stove initially, not from leaving the air open while in a cat burn, or from trying to get too much heat from the stove. I'm very conservative in the temperatures I fire my stoves. Dennis, for instance, scares me! Although I know he knows what he's doing.
I have been distracted and left my bypass open too long on both the Fireview (perhaps three times) and PH (once).
On the Fireview, you have very little time from the stove going from not yet ready to engage cat, to a really hot stove. I have never "overfired" my Fireview, but several times got it a lot hotter than I like, and to where I can smell the heat..temp on stovetop over 650. It always calmed down when I closed the air, so was never runaway, but I would have a very active fire for up to twenty minutes before the flames died completely. During that time, though, there would be no significant rise in temperature. I always felt that the stove could easily get a lot hotter very quickly if left longer with the air open and the cat not engaged. I would note the Fireview takes a good half hour to get to operating temperature.
On the other, the PH gets to a temp where the cat can be engaged in ten to fifteen minutes. And, the PH can develop a roaring fire if you load on a large bed of coals, delay engaging the cat for a bit and keep the air half open, and the stovetop temps will still be around 300. The flue temp will still be in a safe range. And when you close the air, the fire dies down almost immediately. It is more forgiving of operator error and harder to get to really high temperatures, likely because the secondaries engage as soon as the stove gets good and hot even if the cat isn't engaged, and tons of heat comes out the (much larger than Fireview) window quickly, instead of lots of heat going up the chimney and into the soapstone.
So, I would say both stoves are unlikely to be have runaway fires, but I believe it is possible on the Fireview with real operator neglect (if you left the air open, cat unengaged for 45 minutes to an hour?) but very unlikely on the PH. I've never gotten mine over about 525, even when trying to get a really hot fire going, and having the stove crank out remarkable amounts of heat. Higher the stove top temp, lower the flue temp, and stovetop never anywhere near overfired range.
Sorry to be so wordy, but didn't want to leave a wrong impression about these great stoves....
