Kevin Weis
Winter air can be greatly dryer but remember frozen wood doesn't dry. Kevin
well arent you a bundle of positivity
its impossible to say with certainty that wood dries faster in summer because youre not taking into account RH. what about humid summers? that wood isnt going to dry very well.
Start a solar kiln as some of us do.
Most of us use clear plastic.of course the question is...
would all black plastic heat the wood more than clear? you lose the greenhouse concept, but black does absorb heat
Its sad that you feel the help that is being provided is not positive. I really believe that any information provided is positive, as it will help you, but only if you choose to take it.
But, good luck building something of this size that won't collapse in the snow or wind for much less.
Motivated, not challenged!GASP! am i being challenged!?
Then i shall build one. youre right. most will collapse. good thing i have a background in structural engineering.
Ill do the frames in all triangles so that the forces are spread evenly on all three sides PLUS the snow will better slide down the sloped sides.
hmmmmmm... yesssss the gears are turning
THANKS!![]()
My background is about the opposite of a structural engineer, but I really enjoy seeing the work of people who think like that.
When I was younger and before discovering my aptitudes, I thought it'd be a great way to make a living.
I'm more partial to domes myself, as is the plant nursery industry, but i look forward to seeing what you come up with with your triangles.
Those Shelterlogic structures get iffy reviews anyway.
Gears are turning...what about every other panel, black, clear, black, clearBlack blocks the suns rays.
Black on the north side if anywhere.Gears are turning...what about every other panel, black, clear, black, clear
I think you're making this much more complicated than it should be.now that would be a science experiment! clear is obviously the way to go, but WHAT IF there is a better alternative that no one thought of because everyone thinks clear is best?![]()
An experiment that's already been done and done and done. Add your name to to the list if you want. You'll find clear works better.now that would be a science experiment! clear is obviously the way to go, but WHAT IF there is a better alternative that no one thought of because everyone thinks clear is best?![]()
what should the moisture meter read for "seasoned" wood?
Happened to me once. Agree, very rare.Is anybody who is buying wood actually buying stuff that is 20% or less? That would seem to be akin to finding a nugget while prospecting. Rare.
Your right about this.. but heres the thing.. when i did the kiln it wasnt because i needed to dry my wood.. at the time i was 3 yrs ahead, almost 13 cord CSS. I did it to see if i got jamed up, could i get myself out of a jam with out relying on anybody else for seasoned wood. If my experiment failed it had no influence on my wood burning. I had 13 cord and all my storage set up, 3 woodsheds. Your not in this position.. if your experiment doesn't work, your in the same boat next year as your in this year. Looking for usable wood to burn.MeeEEEeEEeh?
isnt this a forum for creativity and getting your hands dirty?
