szmaine said:midwestcoast said:szmaine said:4acrefarm said:I am considering using Refletix as the first layer (staple it to the joists?) in my attic insulation as both an air and vapor barrier and to contain the next layer of cellulose in the event that we renovated the bedrooms, plaster and lather, it would contain the loose fill.
Any critique of this idea is welcome.
If you're installing a vapour barrier in the attic you want it to be below all insulation. Otherwise vapor can get traped & condense in the insulation below the barrier. Mold & ceiling damage possible.
If you're talking about insulating at the roof and not venting below the roof then that would be the right place for the Reflectix, but I'd be very concerned about any water leaks getting into the cellulose & no way to dry with a vap barrier in place
To get the R-value in limited thickness of just the joist bays I'd be looking at spray foam (much less worry from leaks and effective air barrier too).
IMO radiant barrier is effective for reducing radiant heating from hot roofing in summer. Needs an air-gap on the hot side or it's useless. Reflectix also gives some insulation from the bubbles, but it's an expensive option if you have a lot to cover.
Yes, I was thinking in term of using it on the warm side. Spray foam would be great but the it would be stuck to the lathe and we do want to renovate two bedrooms below. We can't do them first because we'd be pulling down a filthy mixture of rock wool, a little vermiculite (asbestos) and mouse turds on our heads. Catch22 going on here for sure. No venting possible here anyway, the house is post and beam.
Can you think of a cheaper barrier to lay down that will contain the loose fill if the plaster and lathe were taken down in the future?
Something sturdy, I've thought of house wrap, landscaping fabric - more ideas appreciated![]()
I'm not sure if I understand exactly. Are you planning to remove the old insultation anyway? Why not remove it, then renovate & instal barrier, then loose fill last.
The vermiculite is a whole topic unto itself. You sure on that?
