Is that from the top of the stove (this will be an approximation, I know) to the top of the clay chimney liner?Grisu, I don't have exact measurement but the chimney looks to be about 10ft high.
I'd think you would be able to heat the entire home with the right size insert. If the doorway between the kitchen and living room is to scale, moving the heat to the entire first level shouldn't be too hard. But I'm unclear about the stairs to the second level...is that stairway open to the living room, i.e. can you see someone walking up the stairs from the living room? It looks from the drawing that the stairs are outside the wall of the house...If I get an insert with good size, would that make significant difference on my gas bill compared to smaller stoves like 1410?
The ones with blower, does it require plugged in?
I have done some homework and leaning toward installing an insert and found a used Country C160 insert selling locally. Any thought on that one? do you think it is still too small for the house? Grisu, I don't have exact measurement but the chimney looks to be about 10ft high. I will try to get you the more details later. Still busy with moving other household stuffs and wife gives me mean look when I stay around the fireplace too long.
With considering all the additional works, I agree the logical choice here would be an insert... but still couldn't give up the images I was thinking when I bought the house. I need your help to forget about the stand alone stove.
/Kosmik, do you know what was the model you attached in your original reply? i got it in from my email and it looked pretty , but pricey.
anyone have experience with Avalon Rainier? has the biggest firebox among the ones I have considered so far.
Both the Fireview and Keystone say 14' in the manual. BIL has 13.5 and Dennis has 13 with no problems. Could OP just run the liner 3' up out of the chimney, no bracing, and call it a day? If there's no problem with downdrafting off the higher main roof, it could work. Kennny, where does the prevailing wind come from in relation to the roof?Another options would be to put a hearth mounted catalytic stove in like a Woodstock Keystone. Being a cat stove, it does not have a secondary burn system and may work better with the shorter chimney. You could call Woodstock and see what they think.
The picture Kosmik sent was this
http://www.doctorflue.com/gallery/wood-insert-4.jpg
It most likely to be at price range out of my budget anyway though.
No idea, just a random google pic that looked closer than others to your brickwork.begreen, if my chimney is too short for it, any way I can extend it? I saw some houses have stainless pipe extended out from their roof. Is it something hard/expensive to get? since I am thinking of installing the SS liner, I could connect it to the extension?
