Insert Scroll Fan Diagnosis
jatoxico
4,369
Long Island NY
One of the fans in my Jotul started "singing". Very high pitch but barely noticed by anyone but me. Sounds almost like a thin piece of metal is touching the squirrel cage as it spins.
It spins fine and isn't stiff but I pulled it so I could oil and clean before it fails. Any thoughts what it could be or what I should look for?
  • Insert Scroll Fan Diagnosis
Bearing failure can start out as a squeal. Clean, then oil the bearings and see if the sound goes away.
So I pulled the offending fan apart and found the bearing that's a bit "tight". They are not sealed but have plastic cap/race covers. I removed the cap and found 6 (?) ball bearings that I regreased but its still not spinning completely free.
It's all back together and it is somewhat better but I guess that bearing needs to be replaced altogether. For the price of a new fan I suppose its worth it but I need to get the exact specs. Ho hum.
