So the chimney sweep company came yesterday to see what we need to go with a new modern insert. Pulled the old insert out of the way and looked the fireplace opening over. They also went on the roof to look down the flue tile to see how it looks up top.
So it looks like they will have to do a chemical strip of the flue tiles from the top(25' tall) to around 10' above the insert. They said that its shiny tar like substance (1/16" thick maybe?) that brushing with a soot eater type tool won't clean it off. I asked about a wire brush and they said it wouldn't get it clean either. They will also probably have to do the smoke chamber area too. In the end I'm guessing the whole thing will get quoted for a price. Looks like just a little work to get the 6" insulated liner in place they said. They are going to send a quote to do all that and install the new insert and insulated liner.
Here's my questions:
1. Looks like to chemically strip the flue they need 60+ degree temps for several days for the chemical to work. That takes burning anything out for the rest of the season(Central Illinois). Not exactly what I was looking for but if that's the only option then I guess that's what it is. Had not planned on spending that kind of money (initial ballpark price of $1800, waiting on firm quote). Is there any other way to remove the creosote?
2. Help me understand why 100% of the creosote has to be removed from the flue tiles? They said they can't get 100% of it without using the chemical. So if the rounded corners inside the flue tiles have creosote why does it matter if there's going to be an insulated 6" liner inside of 13" square flue tiles? The liner and insulation will be inside that void in the tiles and capped at the top.......so what's the need for getting every spec out? My flue temps should be much lower and more uniform to the top, don't see the need for the expense of the chemical strip. I'm sure I'm missing something I guess.
Also working on a solar kiln to get my wood where it needs to be for MC. We have the space to store years of wood, but why when it seems people are having the desired results with the kilns they are building. May give the ShelterLogic (
https://www.shelterlogic.com/shop/firewood-seasoning-shed-10-x-20-x-8-ft ) a try. Still looking at different options.
Again thanks for everyone's help.
Steve
